Just started. Working on my tank unit. Didn't want a pump making noise so pump is going inside. Doesn't look too hard. Going to see if I can figure out how to post pics. Still need to weld a few barbed fittings to the top of the hat. It's a DW 255 pump. Had to hunt up the pump filter. Looks like it'll work so far. Barb fittings will be here in a few days. I'm going to use all 3/8 hose. For supply and return. I bought a Magnafuel rising rate regulator. I'm going to pull the throttle bodies and the fuel rail and weld 3/8s barbs on it also. Looks like pulling the throttle bodies will be a lot of fun. I'll probably throw some bigger injectors in it also. I'll post more pics when I get done.
