Thread: FREE "Custom" PCV Map
Created on: 07/16/11 12:38 PM
RE: FREE "Custom" PCV Map
07/16/11 2:29 PM
No 50 bucks.... Nice.
07/17/11 7:47 AM
Flies out & some fuel pulled. Smooth AFR line you must admit. All safe.
07/17/11 9:33 AM
Very safe.
07/17/11 11:06 AM
If I pay you $50 for the map can I call you.....?
littleburt
08/23/11 5:22 PM
looks like a real nice map i downloaded to disc but how to i download it to the power comander ? i guess what i am saying is how do i get it off the disc that i download it to and get it to the pc? Burt
heathun
heathun's Gravatar
08/25/11 4:33 PM
Dogo what was the 06' 07' map set up with? and did you run it?
* Last updated by: heathun on 8/25/2011 @ 4:35 PM *
08/25/11 5:21 PM
And anyone else that has a "custom" map they are willing to share, please upload it and post the link... It took me all of about 1 minute to do.
One of these days I will have to pull a copy of mine and post. I must confess, I know almost nada about what those # mean. Be interesting to see how it compares to the first map. I have same setup except the exhaust is prolly closer to a smeg or a short meg.
08/31/11 10:51 AM
I just uploaded that Muzzy file and did a map compare with my Ivan-Hoe map, very different. Ivan's is for slip-on Yoshi however so that may explain some of the difference.
08/31/11 10:53 AM
If I pay you $50 for the map can I call you...?
Your customer service suks Dogo, I can call Jeffo anytime for $50...LOL!
Slowninja
08/31/11 11:16 AM
Dogo sezz
Safe enough to run 87 octane (in cool weather), eventhough the map was created running 93.
Sigh..
Octane rating has absolutely no bearing in air fuel readings. You can run 87, or 101 or even 114 octane fuel (as long as they are all non-oxygenated) and the a/f will be the same. The higher octane fuels will make less power, due to the slower burn on the fuel.
I know it's been a while, but i thought we'd been over this?
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
08/31/11 1:00 PM
Correct.... but it does have a big impact on the fuels ability to resist detonation, I think this is what Dogo is trying to say.
09/04/11 6:06 AM
Look at that AFR line! Practically out of the gate all the way up. WOT does that tell you?
Tells me that there is a opening for guys the Jeff to walk in and pull some fuel and make a quick 50. Sorry just stirring it up is all lol. 12.50 AFR to 13.25. Looks like she needed it, No ?
GIXXERCON
GIXXERCON's Gravatar
12/02/12 10:09 AM
I know this is an old thread but has anyone tried this map? I've only been running a FuelMoto map that was provided with my PCV and I would like to see if theres an advantage to be gained with other maps...
GIXX
09 Candy Lime Green - Two Bros full M2 Black edition CF - PCV - Flies out - 17/45 gearing - Dunlop Q3s - DDM HIDs
12/02/12 2:45 PM
welcome. Great map.
lytnin
lytnin's Gravatar
12/02/12 6:35 PM
Curiosity is what happens when one uses a fly out map on a bike with flies in?
12/02/12 7:29 PM
Runs rich in the bottom end.
SPORTSMAN
SPORTSMAN's Gravatar
12/06/12 3:01 PM
Gonna try it.
Tried a Jeffo map, and a remap ....... awful.
Running a PCV Akropovic program .... better, but still not right.
My combo ....
2009
2006 Header, no cat.
Tsukigi race carbon dual slip ons.
BMC air filter
Question from a newbie with PCV, does a new program correct all facets of an old program, such as accelerator pump settings?
Half in the bag here, so I hope I'm saying this right.
SA Octoberfest ....yum!
* Last updated by: SPORTSMAN on 12/6/2012 @ 3:03 PM *
12/06/12 4:11 PM
On my 2012 PCV setup for brock's I didn't have to set any other features...only install and ride.IDK if he had done that in there already or not.
You tried a Jeffo map in your 2012?Hmmmm....I had one also....ran very good with my 07.You're braver than I am....that's for sure;)
"Running a PCV Akropovic program .... better, but still not right"....maybe...you could PM one of those guys over on the EURO section...(here)ask if any have that factory Akro/14R map.One guy said his runs flawlessly...his EURO factory Akro 14R.It's supposed to be a very very good map.
"does a new program correct all facets of an old program, such as accelerator pump settings?"...by 'program',you mean the unit's firmware...i.e.,PCIII or PCV?If you're doing that...the new PC will default to whatever it's set to.Once it's powered on and connected to your ECU.(or CAN)..or whatever.You should have an option in there to 'reset to all default powercommander settings" or something....in 'environmentals'.Nice little deal I think.Well..depending.Anyway..it clears all the inputs someone has entered in there.It will not affect the loaded map.
* Last updated by: Grn14 on 12/6/2012 @ 4:26 PM *
SPORTSMAN
12/06/12 4:32 PM
Thank you Sir!
audioboyz
audioboyz's Gravatar
12/06/12 5:21 PM
I'm glad I got a dynatune on mine.Just for the heck of it I put my Brocks streetmap in.Wasn't as crisp on the bottom or the midrange.Put my tuned map back in.Dude knew what he was doing.If I get a new bike I'll get slipons and a tune.
Craig
2011 Mustang GT 6-Speed 5.0
shift6
shift6's Gravatar
07/30/14 7:46 AM
I know this is an older posting but I would like to get some up to date feedback on the 06-07 version of the map.
Does this work well with slip-ons and flies out?
blue14
blue14's Gravatar
08/01/14 7:55 PM
Hi guys, I have a Muzzy map in my 08. The bike runs consistently good.I have a Muzzy full system, K&N air filter and a PC-3. The pipe end is always black and the gas mileage is about 32mpg. The popping doesn`t bother me. I think its cool. The only issue so far has been the leaking valve cover gasket that I fixed with a few washers. Get the feeling I love this bike?
Can I do any better with a different map or should I leave well enough alone? I do realize that these 14s are not econo-bikes. Thanks, LD
08/01/14 10:06 PM
It's been ages since I checked my mileage. I can fill up and go about 200 down the highway before I'm on E.
My pipe is black so I don't know how sooty the outside is. The inside was not coated but it was soon covered with black soot. It's not greasy. The stockers even will sputter out black stuff. I don't worry about it.
nikoszx14
nikoszx14's Gravatar
06/13/15 7:08 PM
there is someone that has zx14 07mod or any others mods custom map with throttle body 46 or 47?
i need to see the 0%-2%-5% until 4.500rpm
only on this fields dont work whell.
Nvr14
mvvette97
03/30/17 12:40 AM
I don't see any map
