I'm getting conflicting stories or am not understanding what the Woolrich unit is limited to or capable of?
One guy says that you can burn these settings so no code shows, but still needs a fuel piggy for mapping.
Or is it a do-all kind of mapping? For example, if Ivan is flashing only a few settings, he is still handcuffed to making a 'smooth' powercomder map. Is it or is it not possible to map the bike with a Woolrich? Or does it just toggle things on and off like the rpm limiter and the other limiters? The Woolrich has the capability to make a map where this turns the bazza/pc obsolete, correct?
I'll take a shot at this one. Hub the woolich is a complete ECU Edit. You can do it all. The ECU edit now allows the Map maker to decide what he or she wants the bike to run like. No boundaries due to emissions, walls are ALL down.
The image you make into Your Maps becomes a reflection of what ever you the builder think the bike should run like. I build the maps based on years of riding the zx14 my likes or dislikes goes into my flash. Basicly, Ivan, Brock And all us other hackers make the bike into what we think it should be based our impression of what we think it should be.
We know Brock works drag side of it. Ivan works the Smooth and top end as well. For me I work the combo of the two. Hub I know from all these years you are going to work the smooooooth.
Ok, where we fall short. As you say we are still handcuffed.
ECU editing has no way of translating your 350 dollar Dyno maps that you may have just spent a fortune on. That being said you if you try and enter the #'s as a guess you may run the risk of
If I had a Dyno, even then I would have to make my runs and guess what #'s to plug in based on my experience. Afterwards run again untill I get it right. Man is still required in this. And as we know he can make mistakes. This is why Dyno-Jet still has a hand on us.
Currently in My case I translate my #'s into the map Of what I think it should be, then make a run, study all the new data I get from SB6 mixed with PCV Auto #'s using my AFR table then combine % numbers's , Enter all info, Run again. objective is to get all power commander fuel cells to Zero's, then we toss the unneeded hardware. Some times I go blind looking at #'s Hurts Me Weee Brain.
This way is Very dangerous and hard as fuck on tires not to mention Countless tanks of fuel.
Problem, This still straps me to 2000 dollars of electronics.
Ok I see some shops now offer Woolich Dyno Tune. Nothing could be better.
Now lets stand in the shoes of the Dyno Operator. This fine individual has to manually input the data same as we do in our map runs. To date Woolich has No Auto Tune function for Kawi. That being said Dyno operator can't use info from Dyno Jet to tell him What the new numbers are and he needs to guess to get his desired AFR and hp.
Woolich is ECU Edit only. But it can be so much more. Justin has worked out Auto Tune for Suziki Now, We just have to wait. He will get worked out of that I have no doubt as I'm still seeing updates almost every other day. (Work alcoholic). Until that day comes we are still handcuffed to data loggers and man's best guesses as to inputs.
I highly recommend the purchase to anyone who has some experience with tuning. This is by far the best thing that has ever happened for us. Love it.
If I could ever get my hands on Auto Tune Function Inside our ECU's Now that will be a Happy Happy day.
If I made any wrong statements above please fix.
* Last updated by: Romans on 8/11/2013 @ 8:34 AM *
