Thanks, guys. Like I said, I have to wrap my head around the 3-D map or cells? Now, did you see the 5-6 map in 3-D as opposed to the default 1 map? And how do I read the red? Are we rich-red or caution-lean? Freak'inn learning curve here we go! If I read red in the higher rpm, sure seems rich, correct? So maybe catching that rpm to red seems to say that is how I concluded that.
Which sends me to 'best torque' aiming for more red in the green/yellow zones and that low an rpm. See where I'm headed for low grunt, just touch the throttle open and the back wheel lights up? LOL!!!
I'm going to give up how all this works part for part, c++ and all that language. I'm just going to concentrate on this program and learn the curve from there. Care to state what exactly did you radio click an burn, Romes? I can see the rev limiters, and man, you miss a shift, I can blow that gear I missed in a 6,000 rpm spark limit instead, not 9,500 or whatever that default is? Less rpm spin once it catches back into gear. Make sense on that move?
Pretty slick if that does. Crap, you know what I also forgot? I never clicked over to the open toggle. I assume that's just to write over things so you are in the: 'write mode' call it? 'Center toggle: 'saves,' toggle to flash: 'burns it' in. Something like that? Okay, say this is basically what the toggle does: I would assume? And being in the center just lets you look around without writing things, sans, click a 'no' when you remove the hardware, and it says on the monitor, 'do you want to save changes?'
This new computer already froze on me, so I had to wipe the drive and start all over. I'm going to try to download the bin on this new tower so I can study the Wooly on this bigger screen.
* Last updated by: Hub on 8/21/2013 @ 11:34 AM *
