kWATT you did was bring 89 ft-lb around the 4,500rpm. You max'd at 120 ft-lb @ 7,500 rpm = Matched book. I say you shifted the torque in a backspace kind of way. You brought the curve down a few rpm, yes? You are at a preset of 89/120.
The 14 has a preset of 114 ft-lb. Only number I've seen that hit that close was @ 113.point something? That 114 pound window, was one of Brock's maps to his first 14 gen bike. So I don't know if you are going to make any more HP short of massaging subtle things to it. That means more cam, bigger ports, bigger bore throttle bodies to match, different fmp-injectors, etc.
If I could backspace those numbers lower in torque to rpm, that is like electric motor getaway. That's my defense. Bullet away from the light so I have a gap of nothing around me.
