Thread: Ram GPS mount
Created on: 09/23/10 02:37 PM
loadedmind
loadedmind's Gravatar
RE: Ram GPS mount
09/23/10 3:10 PM
Thanks for posting this info Erik!
HillbillyTom
HillbillyTom's Gravatar
RE: Ram GPS mount
10/21/10 7:28 PM
And Cycle Gadgets says they have a store in Eureka Springs Arkansas. That's a great 90 mile backroad twisties ride from me. Have to ride down and check them out next spring.
Thanks for the info..
BearsZX72
BearsZX72's Gravatar
So Cal, Antelope Valley
RE: Ram GPS mount
10/22/10 12:56 PM
I use the same RAM mount for my GPS, works really great. I just need to install a 12V outlet, I run the GPS battery down in less than 3 hours.
Kilcoinzx14
Kilcoinzx14's Gravatar
RE: Ram GPS mount
12/14/10 9:29 PM
CHECK OUT AMAZON.COM THEY HAVE A WIDE ARRAY OF RAM MOUNT SYSTEMS PLUS THEY ARE CHEAPER THAN CYCLEGADGET.COM
I PLACED AN ORDER WITH THEM AND THEY HELD MY ORDER DUE TO A BACKORDER.....I WAITED FOR 16 DAYS AND AND MANY EMAILS WHICH THEY NEVER RESPONDED TOO. AMAZON.COM ALSO SUPPLIES THE POWER CORD DIRECT WIRE TO THE GARMIN NUVI FOR $14....NO POWER OUTLET RIGGING.
RE: Ram GPS mount
02/26/11 10:09 AM
Kilc is right on, Amazon has tons of quality stuff, at low prices. I got both my ram mounts (the kind that attach to the lever perches) from Amazon, and if I ever get a radar/laser detector I'll get one from Amazon to go into the steering stem as well.
I get free shipping if I shop for Amazon Prime items (meaning Amazon stocks it). You'd be surprised how much motorcycle stuff they have. Even if it comes from one of the big mostly-online motorcycle parts store, if Amazon has it, you get it, delivered to your door, cheaper than buying it direct most of the time.
My Zumo 550 GPS is on my clutch perch, and my smart XM antenna is on my brake perch.
Most of you can't do that because you still have your clipons. I have more flexibility because my bad back and neck forced me to put real handlebars on mine.
The GPS is wired into my front fuse block (twisted throttle sells) which sits on the right ram air tube. It is directly wired with 12 gauge wire to the battery. The battery tender pigtails are on the fuse block, as are my 2 BMW sockets.
Amazing how much stuff I've gotten from Amazon.
RE: Ram GPS mount
02/28/11 7:20 PM
Parked Motorcycle Syndrome - priceless !
hoopie
RE: Ram GPS mount
03/02/11 12:04 AM
I ordered this to hook up my Garmin Nuvi 500 using battery tender cord.
http://www.amazon.com/gp/product/B003XMQEK2
2008 Kawasaki ZX14 Saphire Blue. Yosh R77 Full Titanium Exhaust, Power Commander 5, Custom Map, TRex Frame sliders, MRA Touring wind screen, Speed Tactics fender eliminator, Heli Bar Risers, Lawst cause frame plugs,Ketie Tank Pad
KawKrew06ZX14
KawKrew06ZX14's Gravatar
RE: Ram GPS mount
03/07/11 7:44 AM
Here's what my GPS set-up looks like.
Seven
215-500-2366
seven06zx14@gmail.com
