Thread: "Flies" and "Maps"
Created on: 02/08/09 12:00 AM
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
Flies and Maps - What are they?
02/08/09 3:59 PM
When I first got my ZX-14 and started to visit some ZX-14 forums, I saw a lot of discussion about "flies" and "maps". I had no idea what those were. So if that's the boat you're in, this may help:
Flies are "secondary butterflies" or "secondary throttle plates". The ZX-14 has what could be termed "explosive" power. In order to make the machine safer for inexperienced riders, they toned down the delivery of power with restrictors (secondary throttle plates). These plates ("flies") are almost totally closed until 4000 rpm in the first 4 gears and not fully open until around 6000 rpm. The result is a very docile and easy-to-ride motorcycle that also has a very smooth power delivery and relatively slow throttle response in gears 1-4. Gears 5 and 6 start opening the flies much sooner and may also have different fuel maps and ignition curves. Remove the flies and the machine becomes a rocket.
For instructions on fly removal (which probably voids your warranty), click here. Some say it doesn't make a big difference on 08's and 09's, but it sure does on 07's and earlier.
A Map is a specific setup for a Power Commander that adjusts the fuel delivery to the engine at different rpms in different gears. The best "map" settings for a particular ZX-14 configuration are obtained by testing the bike on a dyno. There are well defined and fairly accurate "maps" that can be downloaded from the Power Commander website and from other sources for different combinations of exhaust systems, air cleaners, and flies in or out.
For an example, the "map" I'm using now is for standard exhaust, flies out, and stock air filter.
"Maps" are downloaded into the Power Commander by plugging it into a computer via a USB cable and using a program from Dynojet that came with the unit. -bg
* Last updated by: bgordon on 2/14/2009 @ 1:32 AM *
RE: "Flies" and "Maps"
02/08/09 11:39 PM
Subthrottlesare exactly what bg has stated. You may hear the term flies, butterfly plates, subthrottles, secondaries, or plain old, plates. It all means the same thing. AS you ride the bike, you accelerate at a brisk pace, you can fell that slow, linear climb up the rpm scale. The subs follow more the rpm rather than gear changes. The plate has no idea how fast you are going, being if the GPS or the speed sensor were not attached as in function, the engine could care less. RPM and the ECU work to run any fuel metering needed.
You will hear people talk about "Lean" as if the subs are completely gone, [removed/locked], then all of a sudden there is a fear that because something has been altered, more air can get in and cause havoc? There is a part in the factory shop manual that states it is safe to ride the bike if the sub-system ever failed during service. What the book mentions is that they will raise the subthrottles for you and you may now proceed along without any other modifications needed. Well, say there is a code present and now your sub is on the blink and you need to see the dealer for repair. Where is the lean if the factory says to proceed once they themselves control the subthrottles to lock open? There is no footnote given as a caution that you should not ride the bike {as the subs open to code]. No, it says you are safe to continue riding. Ask that person who told you where that lean came from?
What some people miss with fuel injection is that the crank and air know when the air is going to open the throttle real quick or say... How can the bike engine go lean if you whip the throttle up at idle in neutral? How can you rev your car engine in park and there is no lean when you WOT the throttle. Does it not move so quick you better back off or it will hit the rev limiter or hit redline just like that and ask yourself where is the lean on a fast open throttle from idle?
There are guys that had their bikes tuned on a dyno with the flies out and found no lean or fuel change by altering the fly opening. The air speed is the event. In other words, it is like you WOT the throttle at idle and she snaps to attention. Now, where is the lag at the throttle? So, do you now see that the manual shows it is safe to ride, being that all that occurred was a faster ingest of air as in time? The time is how much faster is the throttle with the '08 and later year; is if the sub was not even present does the '08 whip up the throttle? Do you see the lean is not too lean is now try it without an air cleaner and you will feel the nose dive being it needs to match the speed of air or say bring more fuel than air so it can fill the chamber soon with fuel than the air is where the...
Fuel Trim... comes in. This is where one runs for the Pc unit or a fuel trim device thinking they need to richen the bike for fear of a lean condition caused by the fly mod? I have to tell you that I am very lean if you want to call a gutted exhaust moving faster air; removing a screen of a stock air cleaner that once restricted the air flow is now removed. I have hammered my bike on the bottom end where lean should count. I have zero lag on a fast open throttle. When I removed my air cleaner to ran open ram, yes, I did feel a slight lag and then it took off. I then reinstalled the air cleaner and the bike reverted back to a crisp throttle, no lag, no excessive popping, nothing out of the ordinary where the throttle could not handle the new flow from the screen-less air cleaner, the open exhaust flow, and the open subthrottle shaft locked open in place.
Guess WATT? I do not need a piggy helper. Recently, I took off at high speed, being the officer and I only know what kind of speed I was doing. So, you know I am a high speed hammering kind of rider if you notice how many incidents I have had with the 14. The bike runs like a clock. Not one hint of engine damage from the oil changes, to pulling spark plugs and looking down the cylinders with a scope.
Lean would mean: Piston knocking from excessive heat. Piston holing as if the bike transformed into a 2-Stroke, which either leaned out or detonated itself to death. The water temperature would be out of safe range and boil over. None of this has occurred with the modifications I have followed along with your mods.
If you want more power, then you use more TNT. So, if say we start to add a fuel trim to the peak tune of the 14; this will soften the peak power the bike is in now. You will have more power, but it will be toward the upper power band where it will help. If you fluff the bottom with more fuel, you will lose a slight bit of peak low end boost. That means you will waste all that fuel is where are you going? Are you racing or street riding?
I have set this bike in many stages of tune. I've run with and without a fuel trim. Fuel trim is nice if you work more upper rpm type performance. But if you think because you read others discuss how you can hurt the bike, make them read the FSM; point out where it says you need to piggy if the flies happen to a coded locked position. Guaranteed, you will loose the ragged edge this bike is tuned to. That is why I do not run extra fuel to wash out the crisp response the bike can make all stock. It basically remains stock and has a few mods to help increase a slight tweak to the air flow.
No lean. No piggy. No BS!
Dave
Dave's Gravatar
Sydney, Australia
G'day
02/10/09 11:33 PM
Hi All,
I've got an '06 Blackbird in the garage so I suppose your wondering what I'm doing here....
Well, parked in front of it is my new '08 ZX-14!
The Honda is being sold, long live the Kawasaki.
No really, the 'bird is a great bike but I wanted a change, so here I am, coming to you from sunny Sydney, Australia.
All the best,
Dave
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
RE: Flies and Maps
02/11/09 8:26 AM
Welcome, Dave! There's nothing like the thrill of a new ZX-14. You anywhere near the fires down there?
Sorry about your squiggly avatar. Well have the image resizing software worked better real soon, so you can re-upload it for a sharper result. -bg
* Last updated by: bgordon on 2/11/2009 @ 8:28 AM *
Donny
Donny's Gravatar
02/12/09 10:22 AM
Ditto on the flies out. I can lay darkies down at will in almost any gear and at almost any RPM. However, fuel mileage has gone in the can! I would NOT recommend taking them out unless you are very cautious in your right hand use!
www.drblast.com
Dave
Dave's Gravatar
Sydney, Australia
02/12/09 3:48 PM
Hey thanks BG,
fires are about 500-600 miles south of Sydney, where I am.
Been cool all week but heat wave is set to return to the state of Victoria
next week. So we'll see....
Cheers,
Dave
PS. I know I'm on the wrong thread, sorry. I'm off!
russty
02/17/09 9:32 PM
A question for Hub, I've been reading your posts for some time and you've mentioned a few things I don't understand. I hope you will either set me straight of refer me to some other material for me to educate myself. You often refer to 5 codes, 4 codes and 1 code and the effects these have on crispness, mileage etc. I've seen what I think are your videos on youtube where you call up some FI error codes. Are these the codes you are referring to? Your writings suggest that you've called these code at will. How did you do that? Do these codes simply result from some other modification that you've done or are you making some other change (like an options menu in the ECU)? Thanks Russty
* Last updated by: bgordon on 2/19/2009 @ 4:04 PM *
08 sapphire
02/19/09 2:35 AM
You often refer to 5 codes, 4 codes and 1 code and the effects these have on crispness, mileage etc. Technically, there are 20 codes to the 14. Spark sticks, key-remote theft, ABS are codes to the Euro 1400 and Connies, but for anything that is running you can mess with are about 8 or 9 codes. Did you read Rotty also? He's a flying fukup with book in hand (I believe he had a manual) which stated that the cam sensor has a one time memory in the ECU. Once you shut the key off and the memory is not reading the correct ohm or say the save signal with the key on she will not start. That is a two wire sensor that has no backup but one RAM (random access memory) that was saved for start-up is the ECU knows what cylinder is next to fire. The cam along with the crank sensor are code-less and will kill the bike if the sensor is out of spec, disconnected, or a wire of the two wires are out of the connector.
If you see the video where I use the speech program, and Mz. Puddles tell you the 3 variables to download a code 3 different ways are repeated here. These are the 3 fundamentals to diagnostics. These are 3 wire combination or more you ponder what I just written you do not need to read a book about it. You first have to know what that book is about but before you read the manual, I am showing you the bottom line basics so you ca read that book and figure out how the bike walks to a failure say. Keep thinking 3 as your combo that locks in a full circle of variables.
I've seen what I think are your videos on youtube where you call up some FI error codes. Are these the codes you are referring to? Yes, I am referring to at least 5 of a few more I've tried and let me work the next step and that is your throttle sensor. I am going to work 3 sensors and this full circles your generic computer bike to pile of parts in a box for sale. These are 3 ways to find a no-start condition in your generic computer bike/car/you name it; motocross is FI, the 4x is FI. So like you die with this like spark-fuel-compression is you die knowing the 3V's either fire that Otto up or it does no these are the absolutes are: CS - CPS - ECU got that memorized? FOREVER! These are just 6 of a shit load of fundamentals take it a day at a time.
CS = Cam Sensor remember, saves that correct value one time. Once the next saved value is out of range for that sensor ~ No Start.
CPS = Crank Position Sensor is a two wire sensor like the cam sensor don't forget; has no code backup like a 3 wire sensor, nor does the computer write a save. So no start for sure.
ECU = See the full circle of the 3 that absolutely will not run like fuel, spark, compression? These are the computer no starts to die with. Is the OTTO-engine is tied to a computer? If the black box cannot save a cam signal and the cam reads good, the crank sensor reads good, the fuel pump won't signal, the choke will not ratchet, she is dead you hitting a perfect 12v at it to resuscitate a pulse.
Your writings suggest that you've called these code at will. How did you do that? Do these codes simply result from some other modification that you've done or are you making some other change (like an options menu in the ECU)? Not at all. I am more showing a two step deal. One is to show how the bike will run on backup by using one of the 3 variables. The video where I pull over coast to a stop? This is where I go to the front and disconnect one is a simple disconnect will code any sensor that is not plugged in. That right there shows you 1 fundamental move to cause a code. The question to the journeyman mechanic is when you reinstalled the engine and you see a code on your new rebuild, how did you get a code when the customer came in for a bent fork it was running perfect until you split the cases is what happened?
Silly, you forgot to plug in the water temp sensor. Chew got me scared I thought there was a wire hanging out of it, sheezeeis it was! you pulled the wires and not the connector plastic faces apart is ya pulled a wire out of that sensor's connector side! Man, you really butchered the flat rate of this bike coming out of the frame is shit, look over there... Chew see that wire pinched you crimped the collar down on it and you caused 3 codes by removing and installing that engine is do not let anyone see that rub beer tape over the wire harness you sloppy ass mechanic is get the fuk out of my pit.
OK, did you see the mechanic caused 3 codes just by accident is he met the 3 wire variables all by his actions. These were fundamental moves you can do by a simple disconnect, toggle the wire so the signal is lost to the computer, or set a resistor in between the hanging wire so you rather pinch a resistor down than the wire to ground is a direct short. So why would you want to add more heat to the wire is use the 2 other wire variables > Make it simple on yourself setting a code at will is just disconnect the sensor from the unit or harness.
russty
02/19/09 2:53 PM
Another great post, thanks Hub. I will read it many times... many, many times!
* Last updated by: bgordon on 2/20/2009 @ 7:57 AM *
08 sapphire
02/19/09 3:50 PM
Remember your basic 6 shoe tear FOREVER! You don't? You walked away crying it was so simple the fun die mental case is you be splitting cases wondering what is up in the generic is no one can snow you if they do not know the practical way the OTTO fires with ping and injector signal is air is the only suck. No more orifices to suck out of. Fuel-Spark-Compression never leave the OTTO. Tomorrow this may change, but crank and the ping to on/off is she fires off. No ping = No fire. No crank, no fire. Fuel is the given, remember, remember, remember! Do not attempt this; being it is very dangerous to light off the D-J if you pull the Main throttle sensor. It is not worth it I can tell you 2 attempts and they were scary with the first mule. It may be set alone but I've learned enough trying to find a happy throttle but it almost felt like the J-D lost signal and all that was there was mid to WOT. This is more a technical walk where the ECU and crank sensor will run that one time together. I have eliminated a few of the sensors to walk' in-step' with the practical to the manual is to quantify what was said. I have Rotty to thank for his single cam single saved/then a no start shown as per manual. That is one to remember is Rotty never will forget. It was more how you narrow down the fast (6) fundamentals should rip right off the top of your head you are on the side of the road is pick the 6 for no-start is do not fold, trade it in for a better hand, you have the house covered you forget the Mighty6. I have narrowed down the 'No's column' as opposed to the 'Yes column' that will not start the bike, as opposed to those that will start the bike. Rotty was shitting in his underwear he had his ass covered is no he was clueless is not you anymore. Nor is the better mechanic (Rotty) is he's in the trenches pounding cranium. So, here is where you lighten up your no start conditions down to 2 components. Now I can narrowed the strands down to the hottest of racing wire harness is get it? Hi ya do inn. I have a wire harness yes I do. About 30 pounds lite tear dan you is go an fill in the blank is told you not to show up is gonna nurse you to your trailer is wave goodbye you played big time not reading the FSM correctly. Yes, I am arming a racing bike in the, Gen-near-wreck is watch me build it in mind is any generic wire harness is getting easy about now, right? Cause I have not the body anymore for racing the tricks is my wired brain still preps race in your face = FOREVER! Are we walking the racing/stock hi-performance/cheat is neat is open my mouth use is bet tear watch out. You are welcome russty, is I have no use is more for youth is trick after trick is nothing up my sleeve.
* Last updated by: bgordon on 2/20/2009 @ 7:56 AM *
03/29/09 9:31 PM
G2 owners, do a normal street takeoff, open throttle at least 1/8 turn and pay attention to what happens at just above 3000rpm. That's your flies open wide.
Take the flies out and you will feel much the same thing at 3000rpm but what came before that will have a tiny bit more punch. My guess is that the stock map is not giving you the optimum fuel for flies out below 3000 rpm so you will still feel the bike perk up around there. A good map might smooth it out more.
The extra power below 3000 rpm is easily controlled on the street. It is likely you won't notice much dif at first. It seems the front comes up around 6-7000 rpm after a fast start rolling open about 3/4 throttle. I think initial burst of power contributes to accelleration later on a bit. I also believe you could get the same effect by leaving the flies in and just using more throttle sooner after takeoff. If you get to the point that your openning full throttle right at your takeoff and that's not enough for your purposes, maybe removing the flies will give more of what you're after.
The only time I notice a difference in the bike's behavior is on a hard takeoff. It doesn't have to be like a dragstrip launch, just fast for the street...like when there's some cocky SOB next to you at the light in his ohsofast automobile. I also notice a change when doing a sharp turn in first gear like a 90 degree right at a corner. With the flies out, entering the turn at low rpm, the back tire might want to spin sideways if you are not being very careful getting on the throttle just a touch. If you are not already modulating clutch in this sort of situation, it might be a good idea to start if you pull flies. I always recomend people wait and do it they want to a year or so down the road. It's just not a big bang mod -- but it is free.
I've only heard that a PC is NOT needed for a G2 with flies out because it runs rich enough across the rpm range, stock. 'course if you want to remap, then you need a PC. I plan on installing one soon but I don't know if it's worth it just to try to smooth out the power delivery.
conneaut14
conneaut14's Gravatar
04/06/09 5:17 PM
I read some posts where they said pulling the flies makes it wheelie prone and others that say that isn't the case is it wheelie prone or just the rider and wrist control? How does pulling the flies affect the gas mileage obviously if our in the throttle all day it's going to suck but say normal cruising 60-70mph I've seen posts where they said the mileage sucked and others that said the mileage increased.
2009 Victory Vision Tour Premium
www.ohioriders.net
Toolman44092
Toolman44092's Gravatar
08/04/09 7:47 PM
Can anyone settle whether or not pulling the flies without remapping is going to damage the bike or not? I can't seem to get a straight answer.
08/04/09 8:22 PM
On a G2, absolutely not. They are mapped quite rich stock and the bike runs flies open a little over 3 K rpm anyway. Flies open, flies out, same deal.
G1, I heard a lot of people say they ran flies out on the stock map. I don't recall ever hearing that this caused a problem for anyone. Still, it seems like most G1 owners went with a flies out map to be on the safe side and to gain full benefit of the flies out mod.
stavares105
stavares105's Gravatar
08/06/09 11:24 AM
I have a 08 zx14 with full Yoshimura exhaust system silencer removed and a K&N high flow air filter. I also have a commander III power commander. I was looking to see if anyone has a map for that specific setting because the one I downloaded from dyno jets web site is popping at 3500 rpms when I fully release the throttle.
2008 ZX14 with full stainless yoshimura trc, PC III, TRE, Ignition module, sub throttle plates removed, targa fender eliminator, and zero gravity windshield. Ignition and PC III mapped by Ivan Performance.
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
08/06/09 12:45 PM
Welcome to the forum.
I believe the popping is a common issue even with a good map. Try a search here on the word "popping" and you'll find some discussion on this, and perhaps a solution. -bg
08/06/09 6:19 PM
If I run low octane gas, I will ping. If I run what is recommended, I may not hear the ping so bad if I stall say at a light and fire it back up. That is they only time I hear the ping.
I run 87 octane all the time. I heat up as much as the next 14, no matter me being naked [the bike that is] for more air exposure.
I have locked open my flies being as equivalent to removing them. We control the air flow speed and there will be no harm as I have experimented with so far. So far, I have nothing to report short of the ping on start up with a hot engine, mind you. Cold start is totally different with a cold type chamber. Ping is when things get hot and out of hand like the set in retard to start and some ping occurs for a split second of cylinder fire.
The bike starts, runs smooth, performs more than my expectations is now a spoiled little brat we show up with your stock flyless... I might think twice we tag team some blacktop. If you had a Pea Sea tre routed to your vapor trail is smoke your ass wit out a doubt... Year all choked up, I know. ASkissSlow.
So, I've swapped the non-sub rod throttle body with a sub code being there is none to move. That experiment was performed on the bike in the early miles of the same bike I have now. Now, I have this bike with a locked open sub of the original throttle body. This body has a system that overrides the sub so as to perform as designed. There seems to be no difference between both mods. The bike pings with that faster air being a little leaner on the quicker entry.
If the subthrottle sort of locks open eventually... If the factory has you covered is to lock open the subthrottle... If the bike runs rich to begin with... If I keep picking off feet is beat my meet you for a quick key is within feet is game over I need to prove nothing, I WIN!
Here is wear out my bike is flat out say, no, without a remapping, how come the factory says we have your limp covered you wanna mess with the fly paper, is say... You gonna eat yer cheeeze pay per?
* Last updated by: Hub on 8/6/2009 @ 6:23 PM *
Toolman44092
08/06/09 8:42 PM
Was that last part English?
08/07/09 12:02 AM
That was Hubbish.
MO: if you pull flies on your G2, you might as well remap to get the smooth increase in power you're after. Flies out/ stock map will be nearly the same softness off of idle as flies in. Just put my PC in after running 4,000 miles flies out and stock map. Nice change. Very satisfied. Not to say leaving the flies in and remapping wouldn't smooth out the bottom end as well. I like knowing I have all the control in my wrist. That is now mine.
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
08/07/09 7:19 AM
That was Hubbish.
Toolman:
Hubbish is a language that may be a bit difficult to learn, but you might find it worthwhile to do so... <grin> -bg
* Last updated by: bgordon on 8/7/2009 @ 7:32 AM *
08/07/09 7:54 AM
+1
Hubbish aint no rubbish.
RE: &quot;Flies&quot; and &quot;Maps&quot;
08/07/09 8:50 AM
My bike is very sensitive as you might find out [on your 14] with a cool early morning ride. Before it becomes warm out, this bike wants to stand up and start hopping over bumps. Imagine if I had the 1/5th throttle and my wrist flinched on the bounce.
That means, I can tell the leaner crisp running bike being stock as opposed to being fuel trimmed with a piggy cutter. What the piggy does is fluffs the 1/5th throttle somewhat. The fuel more cuts the more sensitive lean. The bike runs a touch smoother... You might like that feature on the pig.
But, once you come up next to traffic and would like to move the idiots out of the way, you more or less have this rich lag and the trim of the lean is lost as far as, 'pep on the ragged edge.' Pretty easy to figure out that if you pig the fuel cuts for an increase, you increase HP by feeding a bang of more TNT is obvious.
So, there is a fine line you have to play with on the pig setting. Would I have to adjust to the morning cool air? I would. I would have a dyno in the garage [almost bought one] to reset the piggy trim for the day. That is how sensitive you are going to be, playing with a piggy, once you hear the call of another map to try.
I had a pro port a Superbike head [for an example]. Once I rotated that bike for another class, I would street it for sale or trade it in. That head was morning sensitive during the months of weather changes. That is how you play with these piggy rigs and performance changes. You will ruin the "drive-ability" of the bike. Especially for the street, IMO.
If I want bottom grunt, I'd mess with air out of the pipe. If I want all out hard riding/racing, then I'd have the bike setup for top end and piggy up. Sea change in the tune; you mess with one variable? Grunt for air is the bottom. Chase the HP up top is piggy tail more TNT; pin it on the dawn key fob and call it done, ready to go.
WaxgONe/Whacks OFF = Sin Say my TogglesettingonnassockeYoUPissEarsensorsockets.
* Last updated by: Hub on 8/7/2009 @ 8:51 AM *
kevincopperhead
kevincopperhead's Gravatar
05/22/10 3:14 PM
Nice info
REDwings08
02/18/11 1:51 PM
My first post, I have a 2010 zx-14 i just had the flies out, PCV and new full yoshi system, after about 200 miles my bike doesnt go faster than 45 and takes forever to get there. It also sevs high when i start out, this just started happening to the bike, I am gonna take back to the shop unless there is a easy fix i can do at home..Any help
xxxses
xxxses's Gravatar
07/30/11 9:11 AM
Hey Redwings08 try posting in the Q and A section you'll bet more responces to your question ...But it sounds like your pc needs to have the latest firm ware and a remap also you might add what yr your bike is and type of pc ie pc3, pc5 i am no pc pro just done lots of reading on our site welcome and it is a easy fix others have had it and goten it together
