There may be some obscure connection between that 'dead' pit...and yer....'custom' bolts...????J/K;)
Actually, Grn, the bolts I am using are from ProBolt. They are Ti steel. That had me very concerned at first because Ti is not only lightweight, I think maybe it is supposed to be a tougher metal than ordinary steel. Well, turns out tougher metal holds up better to tapping and grabbing which is the approachI am going with first. If that doesn't do it, this stuff does not seem SO tough that I cannot dremmel and drill a vertical axis pilot hole. ....makes me wonder if a soft aluminum bolt shank would be easier to extract or more challenging?
The problem is that these are NOT really rotor bolts. Rotor bolts need to have a shoulder to prevent stretching the threads in the wheel (which I think I did do) and also to better hold and center the rotor in position. CZ really should have designed the front brake rotor carriers better. The rear has larger shoulder bolts. Front to small IMO and should really have a shoulder. I will most likely mod the rotor carrier holes in the future to accept a shoulder bolt or some kind of sleeve. but tghat is for the other thread. This is just about bolt extraction.
* Last updated by: Rook on 5/31/2013 @ 6:21 AM *
