Can a clutch issue result in a charging issue?
I can see how the two problems might be related although I'm not very knowledgeable about how the alternator works yet. If the input shaft turns a shaft that drives the alternator as it does the engine sprocket, when the clutch slips, there would be a reduction/loss of power to both the front sprocket and the alternator drum that rotates around the coil of wires creating the electromagnetic field which charges the battery. So a long ride home with clutch slipping would draw the battery down.
I'm not sure I am correct about this but if you look at the positioning of the stator cover, it sure seems in about the right location to be turned by the input shaft. The input shaft, I know has no power in it when the clutch lever is pulled. That's why the clutch does what it is supposed to do when you stop in gear, take off or shift gears. the clutch lets go fully or partially according to how far you have the lever pulled. For some reason, your clutch is not doing what it is supposed to do which is to grip the transmission when the lever is released.
I would charge the battery up and don't worry about the fact it drew down with the motor running. Unless Hub or someone else can refute my hypothesis about that input shaft driving the alternator, what happened to your bike is to be expected and will rectify itself once the clutch is fixed.
How much should it cost about to fix a clutch if that's the problem?
Depends on the exact problem. If it were just that the top couple plates fell out of place, that would be a matter of reassembling the clutch plates. Remove cover and fallen plates, inspect for hub/drum damage, if none reinstall the plates that fell out. Inspect pusher rod and thrust bearing....what else could it be?? Inspect clutch pack height? If your clutch wasn't slipping before, all those must be good.
1. Small possibility the cold shrunk the clutch pack height enough to allow slippage but unless you've been doing drag launches, I doubt the clutch plates could be worn enough in 14,000 miles to allow that tiny amount of shrinkage to make the clutch slip if it was holding in normal weather. Anyway, your oil temp probably went close to normal if the clutch was slipping for even just a little while. Probably the clutch pack height is (was) ok cold and hot.
2. Slight possibility the clutch plates were installed wrong at the factory. If the outermost one is not installed with the tangs in the special grooves rather than the fingers like all others, the outermost plate can fall out which definitely would reduce the stack height enough to slip. Probably not since this would have happened a long time ago if the clutch plates were not installed properly.
3. Clutch pressure plate is not retracting into the drum and against the stack of plates. You would feel extra slack in the lever at first but after you squeezed the lever a couple times, the fluid in the reservoir would fill the void and you would have normal pressure and normal lever feel. Your pressure plate might remain extended until the springs pushed it back in also pushing the extra fluid back up to the reservoir.
Why would the pressure plate have not retracted under the more than adequate spring tension of the clutch springs? Something would have had to have stuck. The master cylinder (probably not), the slave cylinder (more likely) or the pusher rod which is probably only lubricated by oil seeping in from the clutch compartment (most probable) or the thrust bearing pusher which is an extension of the pusher rod (possible but unlikely). It is possible that the thrust bearing and/or washer it rides on stuck from cold oil. Those parts could then fall out of place (probably down in oil pan and take them out when you drop the pan someday) and that would reduce the clutch pack height by a few mm which is a few times the allowable service limit for clutch plate wear and that would definitely make the clutch slip.
I say you have a look at the clutch plates through the oil filler hole first. Take a pic and post it. Be a 15 minute job and you will see if your pack is drastically off which I suspect it is. Then you decide if you want to take this in to the dipshits at the shop or do it yourself. I know I can guide you through a clutch pack assembly so it's up to you. It is complicated enough that careless mechanics under pressure could screw it up. I have a tutorial that would help a lot.
I have a feeling you will need to replace some fiber plates. A hundred fifty bucks. Get OEMs. Maybe you will need to adjust the clutch height which means one or two steels, maybe $30. Maybe that washer or thrust bearing--$20. Hopefully there is no clutch hub or drum gouging. If it were to be bad, that's $400-$600 for one or both. Probably fine if the clutch was just slipping and not grinding.
Very little chance of engine damage . Any pieces or particles would wash down into the sump. If this is the case, you will want to drop the pan and clean it and the pickup screen at your earliest convenience. Could be an oil pressure issue.
This is a little on the complicated side for a beginner but very doable if you have the time to wait for replies. The hardest part is keeping every part in the same order and orientation it came out in but that is not crucial. Probably no one has ever put one back the same way it came out exactly. You will probably be installing new fibers anyway so the exact position of the fiber plates will not matter.
HOW TO REPLACE CLUTCH PACK-GEN1 IDK if the Gen2 is exactly the same procedure but i would bet it is aside from different specs for clutch pack height, wear and maybe torque specs.
pull the oil cap first and snap a pic. be careful about the camera angle, that can be decieving. get right above like the pics in the tutorial below.
clutch inspection
If the stack height looks good from the oil filler hole, drain oil full or partial and then remove the clutch cover. You might see the problem right away. If all the pieces aren't there, that's the problem.
* Last updated by: Rook on 2/17/2018 @ 5:36 PM *
