Thread: Supersprox
Created on: 08/18/17 05:40 AM
Supersprox
08/18/17 5:40 AM
I know it's probably been stated previously, but Supersprox rear sprockets are practically indestructible. Just pulled mine with 52,000 miles of use and you can barely tell a difference between it and a new one. Could have cleaned it up and saved $90.
RE: Supersprox
08/19/17 11:15 AM
I have a Supersprox front. As mentioned on another thread, I have to have a look at it.
'08 MIDNIGHT SAPPHIRE BLUE flies out, full Tsukigi Cannon exhaust, BMC race filter, Muzzy's block off plates, 17/45 gearing, PC5, Romans map, AT-200, Bonneville PRO, HM PLUS quickshifter, Factory Pro EVO Shift Star, RC's oil pump cover, Shorai 14A2 Lithium battery, Spiegler SS clutch and brake lines, HyperPro RSC steering damper, Vortex rearsets, Ohlins FGRT807 forks and KA544 shock, Carrazzeria Tri-R wheels, Pazzo levers.
RE: Supersprox
09/01/17 7:11 AM
If you're interested in a good 41-tooth SS rear, buy mine for $35, clean it up and run it another 52K miles. I was sent an 18T front and the only difference I can tell it the chain rattles slightly on the primary sprocket surround. Once moving, the noise goes away, but pushing it around the garage is a laugh.
* Last updated by: Danno on 9/1/2017 @ 7:12 AM *
RE: Supersprox
01/07/18 1:54 PM
this is a closeup of the 50,000 mile sprocket on top of a brand new zero-mile example.
* Last updated by: Danno on 1/7/2018 @ 1:57 PM *
RE: Supersprox
01/07/18 4:46 PM
I'm not much of a sprocket Dr but to my naive eyes the well used one one doesn't look that different than the virgin?
"I'd rather use tampons then slipons." Rook
RE: Supersprox
01/08/18 4:16 AM
same here. I'd put a virgin chain on that experienced sprocket any day.
* Last updated by: Rook on 1/8/2018 @ 4:17 AM *
RE: Supersprox
01/18/18 7:15 AM
That experienced sprocket wore out what was left of the original chain and two more brand-new ones, so I figured it was time for a replacement. Had I known how little wear there was, I probably would have just replaced the chain and front sprocket which was toast at 70K
* Last updated by: Danno on 1/18/2018 @ 7:18 AM *
