Thread: Coolant Reservoir Blackout
Created on: 09/22/15 02:16 PM
09/22/15 2:16 PM
I always found the coolant reservoir somewhat unsightly even with the fairings on. Blacking the reservoir out makes it a lot less noticeable and Plasti Dip is a good alternative to paint because Plastidip is easy to remove. However, you will have to look a lot harder at the back of the bottle with only a small window left open to view the coolant level.
It’s pretty simple to apply Plasti Dip but masking areas presents a bit of a challenge. The dried coating stretches and does not break cleanly along dried tape lines. The edge must be neatly scored with an exacto knife before pulling up the tape. While not perfectly clean, the scoring method works fine to make a window on the coolant reservoir which is hidden under the fairing for the most part. The video link below shows a process of removing the tape while the Dip is still wet. I have not tried it but I think that approach would be preferable to scoring the edge of the masked areas as shown in this tutorial.
https://www.youtube.com/watch?v=2kBWaSDmj0g
Tools:
Masking tape
soap and water
exacto knife
a piece of wood
two 1/2” x 3/4” wood screws
screwdriver
black Plastidip
Do first:
*Remove the LH Forman, Fuel tank Fairing, LH ram air cover, LH Lower and LH side fairing (see Fairings Removal).
*Remove Coolant Reservoir (see Radiator Flush and Coolant Change, step 3). Disconnect the two small hoses from the reservoir. Several ounces of coolant will probably leak out when the lower hose is disconnected so be ready to catch that in a container. Empty the rest of the coolant from reservoir.
1. Remove the reservoir cap. Mask off the two nipples and the threaded potion of the filler neck.
2. Wash the outside of the coolant reservoir with soap and water. Make sure no soap or tap water contaminates the inside of the reservoir. Let the outside of the reservoir dry thoroughly and wipe it with denatured alcohol.
3. Use masking tape to cover the areas that you will use as windows to check the coolant level in the reservoir. Use an exacto knife to trim the mask to whatever size and shape you like.
This picture shows the initial shape I cut for a side coolant level window. It seemed too prominent after installing the reservoir. I later masked a narrower portion and resprayed it. However, making the window too small will make viewing the coolant level difficult.
There is a mark on the side of the reservoir that seems to coincide with the Low mark on the back of the bottle. With this small of a window, it’s pretty hard to read without shining a flashlight in the top of the reservoir.
4. Fasten the reservoir loosely to a piece of wood with two 1/2” x 3/4” wood screws. This will make a convenient handle to hold while spraying the reservoir.
5. Apply two wet coats of black Plasti Dip. Wait 30 minutes between coats. The back of the reservoir is not visible when installed but you may coat it after the front has dried.
I don’t recommend doing a light tack coat as is sometimes done with spray paint. Plastidip applies in a coarse spray and it is likely to cause some graininess if it is applied lightly. Apply the dip wet so it flows. The hollows where the screws are located are a bit challenging to spray without getting a run but you should be able to cover them after a couple coats.
6. After the Plasti Dip has dried, use a brand new exacto blade to score along the edge of the masking tape. Carefully pull up an edge of the the mask and pull it off.
A dull blade will skip and give you a ragged cut that will pull up the Plasti Dip. You should not need to press hard at all to score the Plasti Dip neatly if you use a very sharp blade.
7. Install the coolant reservoir and hoses. Fill the reservoir with proper coolant to the H line.
Reserve Tank Bolts, Torque: 87 inch lbs., use non permanent locking agent
Install fairings.
* Last updated by: Rook on 12/2/2017 @ 12:58 PM *
'08 MIDNIGHT SAPPHIRE BLUE flies out, full Tsukigi Cannon exhaust, BMC race filter, Muzzy's block off plates, 17/45 gearing, PC5, Romans map, AT-200, Bonneville PRO, HM PLUS quickshifter, Factory Pro EVO Shift Star, RC's oil pump cover, Shorai 14A2 Lithium battery, Spiegler SS clutch and brake lines, HyperPro RSC steering damper, Vortex rearsets, Ohlins FGRT807 forks and KA544 shock, Carrazzeria Tri-R wheels, Pazzo levers.
knovikov
knovikov's Gravatar
RE: Coolant Reservoir Blackout
09/22/15 7:51 PM
That looks cool, Rook. Now I will go and make a window on my reservoir - great idea. With the number of hours we racked working on our bikes, it is unthinkable to sell it.
09/23/15 9:25 AM
Haha--you might as well if you're going to have it out in the open but be aware, it is harder to read the level. I wouldn't go any smaller than the window I have on the back of the bottle. Someone recently posted that he eliminated the whole bottle and the two tubes going to/from it. He just left the tube from the radiator pointing down to the ground and ran the bike at whatever coolant level it overflowed to. I might try it someday. Might not be the greatest for turbo bikes, though.
12/02/17 1:02 PM
I just removed the coolant reservoir. 2 years later looks as good as new. The only place it pealed a little was where it stuck to the underside of the bolt heads. I'll throw a couple nylon washers under them and it will last another two years if need be.
12/03/17 8:56 PM
"tube from the radiator pointing down to the ground and ran the bike at whatever coolant level it overflowed to."...ahem...Mr Rookster...I would seriously rethink that idea if it were me.Unless you REALLY wanna wind up on yer ass out there.Nothing like a good SLIDE to get ya back in focus..just sayin;)Hard for me to believe they just stuck that res in there for shits n giggles...know what Imma sayin?
To quote a beloved member here.."Aint MY bike'...;)
You did a most excellent job with that.When ya get outta the hospital,you can get back home and hold that little jewel in yer hand and say.."Wow,,I coulda had a V-8!"
* Last updated by: Grn14 on 12/3/2017 @ 9:00 PM *
12/04/17 5:20 PM
I'll probably look into it further but as far as I can tell, there is very little if any expansion going to my reservoir. It's always on LOW. I don't think much more than a few drops would ever go onto the road. Maybe if it got really hot.
