Common and part of the maintenance intervals. Mine knocked within 600 miles. So the observation goes something like this.
1. Top crown: Loosen center nut and pinch bolts. This unloads the locker rings. Tap the lower locker cw so both lockers move together. If one was to disassemble the lower crown to grease the bearings, then yes, spin the top locker off after bending the lock tab, etc.
2. Bearings: One has to understand the difference between loading the balls as opposed to removing the knock. Thus, having the balls remove the knock, but are loose as a goose>> once the rings are under load.
3. Center Nut. That torqued nut; pulls the lower crown's [stem's] threads>> up against the locking rings. The top crown is lowered and needs to statically run down the fork tubes/legs. All of this has to be noticed if one is to attempt to making an adjustment. Noting how the parts are stacked on that center stem and what happens to the bend of the top crown; if one just unloaded the center nut only. This would flex a V at the top crown>> if one did not address the pinch bolts as well.
Still confused on setup?
How does knock occur:
a. The races move in the neck or are sent home in the cut, to being shot-peened like into soft metal until hardens.
b. The balls are flattened as they indent the races so both ball is being shot-peened flat as is the race becomes concave in profile. Moving from side to side to see the room light reflection would show an indented shadow. This would drop in the pocket or center itself and not swing away to either fork lock side.
c. The triple crown system loosens up somewhere. The rings walk. The center nut, the stem walks, etc.
Make sense now?
