Thread: Mirror Block Off Plates
Created on: 02/28/18 02:39 PM
danfzx14
danfzx14's Gravatar
02/28/18 2:39 PM
Does anyone have any recommendations for Mirror Block Off Plates? I am reluctantly contemplating removing mine because my wife's new SUV is making it so I have to fold the mirrors in every time I take the bike in or out of the garage. I Really like the Brocks carbon fiber ones but would like to here from anyone who has done this to there bike. Thanks!!!!
RE: Mirror Block Off Plates
02/28/18 3:40 PM
I bought Vortex years ago. They have worked just fine but one of the studs broke off when I tried removing the nut which was not tight at all (in plastic, be careful with torque) but it was blue LockTited. I till am using it. The other studs have held just fine.
Get a cheap bar end mirror. It may be hard to fit one on the throttle side side. It was with my current setup but I got it to work. I don't recomend expensive bar end mirrors like CRG. The cheap knockoffs have just as good of glass and if you get one with two pivot points, it will adjust as much a san $80 CRG plus you might get two under $15. The only think that is better about my CRGs is that they can go to a higher speed without folding back from the wind. This not an issue at legal speeds and folding the mirror back for speed runs is not a bad idea anyway.
Cuff
Cuff's Gravatar
03/03/18 10:48 PM
I have two sets of these. One drilled and tapped for Ram mounts and one for show. Never an issue even with a camera on.
https://www.amazon.com/Motorcycle-Mirror-2006-2009-Kawasaki-ZX-14R/dp/B00RW3EJBO/ref=sr_1_2?s=automotive&ie=UTF8&qid=1520142364&sr=1-2&keywords=zx14+mirror+block+off+plates&dpID=512ZZrvnfxL&preST=_SY300_QL70_&dpSrc=srch
Blkcasper
Blkcasper's Gravatar
03/16/18 11:56 PM
There are a number of block off plates on ebay and amazon. Any year zx14 will work ass the mounting holes are the same for all years. i have the black ingraved st and a chrome engraved set. just make sure you use locktite on the bolt that goes into the block off base. I also have the exaghust hanger plugs, There a nice touch to cover up the open holes if you remove the stock exaghust
Your text to link here...
* Last updated by: Blkcasper on 3/16/2018 @ 11:59 PM *
Luvin My ZX14R'S.
