"Rook I dont understand why you tore apart the whole back end to do this job? all you really need to do is remove the tool box and move ecu outta the way. like the how to pics but imo you took it much further than you needed to for this mod lol i think you just like undressin the old girl lmao" Yeah, you're right.
The brake light and sides of the tail need to come out in order to get a wrench on the last nut that holds the fender to the underside. The front two bolts (under the ECU) that fasten the fender have threaded sleeves that remain stationary but the back one has a nut and washer instead. When I turned the bolt under the bike, the nut rotated so it was necessary to hold the nut with a wrench. It was also a lot easier to pick the nut and washer out of there after the bolt was removed. Maybe some people are lucky enough to have that nut stick while they turn the bolt and they don't mind leaving the nut and washer in there to bounce around until it falls out. I am a bit of a perfectionist, I guess.
Rook you do some excellent tutorials here that many appreciate but in this case I have to agree with Scottjykl. Alot of those steps are eliminated if you simply just lift the hole ECU/relay box right off their mount.
I believe there is the screw that your removed everything to find
and one of these makes it easy to pick up those loose stray nuts and bolts so they don't have to rattle around and fall out.
I can't take credit for any of this. I forwarded this thread to my friend bigbore when he bought his blue 14r and our friend dave (an aircraft mechanic) looked at it and did it this way in about 15 minutes total including the bolt light. Me, came off great but couldn't find a bolt light locally today.
Thanks again for all the effort you take doing these.
