Thread: Tank bag for 14R
Created on: 04/17/15 09:45 PM
aryan
aryan's Gravatar
Tank bag for 14R
04/17/15 9:45 PM
Looking to pickup a tank bag for 14R...
1] It should be really easy to install {magnetic will be better}..
2] Not very big..
3] Pouch in the front to put a 5.5inch phone which can be used as GPS navigator also...
Please let me know your preferences...
Carve faster, Ride harder, Cruise longer.....
Hyosung aquila gv650
Kawasaki ninja zx14r
WildPete
WildPete's Gravatar
RE: Tank bag for 14R
04/18/15 7:02 AM
Why magnetic, those will scratch up the tank.
I have a tank bag but prefer it off the tank. I use a Givi bag and adaptor that raises it off the tank.
doubleD
doubleD's Gravatar
04/18/15 11:57 AM
If you use a Magnetic attached tank bag, NEVER pull the bag off the tank. Always fold each pad up and away. And check the magnetic pads often, they pickup debris.
I use 2 tank bags from Nelson-Rigg. A small one, CL 1025, for around town and the larger one, CL 1030, for traveling.
Nelson-Rigg bags are made from Nylon and do not fade. Mine came with rain covers. Nelson-Rigg has changed their mounting attachments. I use clips in the front (around the steering stem) and magnetics in the back. I just detach the back and swing the bag forward when I refuel.
Any tank bag touching the surface will scratch the paint over time. Keep the tank waxed and maybe get 3M Invisible Bra installed.
1969 350 Suzuki,1972 500 Kawasaki,1974 900 Kawasaki,1977 XS750 Yamaha,
1978 XS750 Special, 1981 750E Kawasaki, 1982 650TurboSeca Yamaha, 1984 700Nighthawk,
1986 Concours Kawasaki, 1989 ZX10 Ninja, 2003 FZ1 Yamaha, 2012 ZX14r, 2007 1250s Bandit-Sold other Bikes, the ZX14r still survives.
SlowBen
SlowBen's Gravatar
04/20/15 6:15 PM
I use a cortech magnetic bag. It has a clear pouch on top that you can put a smaller tablet in. It comes with a water proof cover that stores in its own spot. I use it for riding to work, I can carry my lunch and a drink or two. Best of all it doesn't get in my why of riding
Speed is an allusion of previous experiences
2013 ZX14R AH2 with Cblast flash,yoshi fender eliminator, stompgrip tank pads, ASV levers.
04/20/15 9:16 PM
I have the Cortech that slowben showed and the joe rocket manta, both very nice designs
"I'd rather use tampons then slipons." Rook
04/21/15 7:32 AM
I have Oxford magnetic tank bag,just always check the magnets for debris before putting on,I also have an Ogio back pack which is fantastic , no wind drag at all,removed the Belly strap nuisance to do up.i prefer the ogio over the tank bag .
aryan
aryan's Gravatar
04/22/15 8:05 AM
Thx guys i checked the magnetic bag at a local shop and the dealer told the same thing.. In long run, it will scrap off the paint... Advised to use a cloth between the tank and tank bag...
DARRYLE i do have a ogio mach5 bag, but i need more luggage capacity so was thinking of picking a tank-bag with kreiga saddle bag...
DoubleD will check the nelson-rigg bag online.. looks a good option to me.
04/22/15 8:45 AM
Aryan, never had any scratches from Oxford tank bag on either my 07 or 2012,I do put on a good coat of wax before a trip,also have Oxford panniers with them I use a lot of electrical tape on tail piece to stop scuffing
aryan
aryan's Gravatar
04/22/15 8:53 AM
Thanks darryle.
What happens when you apply sudden brakes at high speeds? Does the magnetic tank-bag skids or remains firm on the tank?
04/22/15 8:58 AM
No problems with speeds up to 250 kph,I also sometimes lay on it on very long rides
aryan
aryan's Gravatar
05/02/15 11:33 AM
I picked up the magnetic tank bag today. Tomorrow is ride day will put it to test tomorrow. will c how good its at speed above 180km/H..
Functionality wise looks a great deal though.
jtemple
jtemple's Gravatar
05/02/15 5:25 PM
If I bought anything to put on the tank it would be the SW Motech Quick Lock. I think they are designed not to touch the tank, but to instead sit on the tank ring. Not cheap, though.
AJBT
AJBT's Gravatar
10/15/17 4:39 AM
WildPete,
Are you using a Givi Tankloc or something different, and which model Givi Tankbag are you using?
I'm looking at the Givi XS307 but can't find anything about the right tank ring to use with a 2017 ZX14-R
AJ
Current - 2017 Kawasaki Ninja ZX-14R - Twin Yoshimura R77's, Givi 3D600 Panniers, Givi V47NN Topbox
Previous - 2013 Kawasaki Ninja 650R - Stock
Previous - Suzuki Intruder 250
ominousone
10/15/17 6:25 AM
The Givi tanklock looks to have a few size options. I have the larger Cortech Dryver that is on my '16 ZX14 all the time, also a tanklock system. In fact, I rode to Calif from Minn, and back, with the Dryver and soft saddle bags. That system works great and the bag doesn't touch the paint. Almost as easy to use as a magnetic bag, which I used a few over 30 years.
ominousone
piken
piken's Gravatar
10/16/17 5:19 PM
SW-Motech EVO quick lock
Several sizes. Like others said, I'll never go back to magnetic tank bags again.
I've had mine for a couple of years and use daily and has been great.
revzilla Evo
EVO
Bopropucope
Bopropucope's Gravatar
10/17/17 9:10 PM
I have 2 different size Cortech tank bags and have never had a problem with scratching or falling off. I also wipe my tank clean before every use though. I do like the looks and options of the SW-Motech EVO quick lock.
AJBT
AJBT's Gravatar
10/18/17 2:17 AM
So I spoke to Givi over the weekend,
If you have a 5 bolt tank ring (my 2017 ZX14 is) then the appropriate flange from Givi is a BF04...
which would have been nice to be able to find on their website....
I was originally looking at the XS307 tanklock bag, but Givi's website don't list the required flange.
instead I went down the SW-Motech path and ordered the following:
SW-Motech Quick Lock Evo Ring - Kawasaki 5 screws TRT.00.640.14001/B
SW-Motech "Daypack" Tank Bag BC.TRS.00.108.20001
Map Holder for Daypack BC.TRS.00.150.10000
Tank Bag GPS Mount Bracket BCK.GPS.00.010.100
Navi Bag Pro Large BC.GPS.00.009.10000
When it all turns up I'll take some photos of it on the bike.
AJ
extrapolator
extrapolator's Gravatar
10/18/17 9:26 PM
Looking forward to seeing that setup AJ
'13 ZX14R; Puig hugger & windscreen; OEM center stand; Helibars risers; Givi V47 Tech top case mounted using an SW-MOTECH Alu-Rack; and Muzzy dual black stainless slip ons
10/18/17 10:02 PM
Check out the Kriega US30 bags for sport bikes, they are really a nice design for our bikes! Not a tank bag but works great on the rear seat
islandninja
islandninja's Gravatar
Bintan Island, Indonesia
10/19/17 7:53 AM
the winning combination for me... at this point:
Kriega US30 for the rear seat & Givi magnetic tank bag
both get to sit on rubberized non-slip mats
not a scratch mark after a 2-months tour in relatively tough environment
KoflaOlivieri's Gravatar
10/19/17 9:38 PM
I've been using a magnetic tank bag for the past 3 years, not a single scratch on my fuel tank.
http://koflaolivieri.typepad.com/zx14r/
http://koflaolivieri.typepad.com/photography/
2010 Kawasaki ZX-14
1984 Kawasaki GPz-1100
1977 Kawasaki KZ-1000
1975 Kawasaki Z1-900
1974 Kawasaki 750 H2 triple
1972 Kawasaki 750 H2 triple
islandninja
10/20/17 2:10 AM
good stuff... i find magnetic tank bags are easier to handle when filling up petrol too...
bryan
11/27/17 1:11 PM
I have a bagster leather tank cover and a bagster stunt tankbag the have mounting points incorporated into the cover quick easy and secure
