Thread: Steering Stem Ram Mount
Created on: 07/13/14 04:58 PM
nasty
nasty's Gravatar
University of Okoboji
07/13/14 4:58 PM
Who here uses a steering stem ram mount and what's the best?
2013 Super Fast SE ZX14R
Forever Fearless
-Clint Eastwood
gobrian77
gobrian77's Gravatar
RE: Steering Stem Ram Mount
07/14/14 8:06 PM
Have a look at http://www.techmounts.com- they make some pretty good stuff.
07/14/14 8:36 PM
I have a Techmount steering stem mount but it's not a ramball. Very nice but DO NOT use any kind of lube before installing with the hope that it will come out easier. The orings may swell and they already fit veru tight. I used silicone spray and I ended up taking off the fender to stick a dowel up from underneath to tap it up with a hammer. I wouldn't leave one of those in for long unless you plan on having it more or less permanent. I usually only push mine in the first two orings.
* Last updated by: Rook on 7/14/2014 @ 8:38 PM *
Bradley427
Bradley427's Gravatar
07/17/14 4:41 PM
RAM systems stem-mount. It located the ball at the stem nice and centered for any video recording of the gauges or thru the windscreen. Super stable I've personally speed verified it to 196mph, lol. The cradle I use is made by RAM themselves, not a 3rd party aftermarket and it locks an iPhone is solid as a rock in one snap motion. 3" long arm with a large enough knob to use it while wearing gloves. They also offer a locking-type arm so you can leave it all on the bike and take the key with you. Best mount on the market IMHO. Law enforcement uses RAM to hold their laptops, and the forklifts at work use RAM stuff to mount all sorts of equipment to the roll bars and dashboard.
A basic stem setup will cost you about $50. Only downside I have seen is most steering stabilizers want to be mounted in the stem as well, so it's one or the other. Or else find one like the hyper pro that can coexist with the ball installed.
Sold: 2012 Kawasaki Ninja ZX14R
Next: _________ ????
jtemple
jtemple's Gravatar
07/23/14 5:50 PM
I use RAM Mount. No problems in nearly 8000 miles.
nasty
nasty's Gravatar
07/23/14 6:33 PM
Is this the one? https://www.denniskirk.com/ram-mounts/motorcycle-fork-stem-base-w-1-in-ball.p599204.prd/599204.sku
I'm buying it right now.
Forever Fearless
-Clint Eastwood
jtemple
jtemple's Gravatar
07/24/14 6:29 AM
That's the one.
jimmymac
jimmymac's Gravatar
K.C. MO Northland
07/24/14 6:50 AM
I hope it's right. I just ordered one from that link.
Let's roll
08/08/14 12:41 PM
I've got a ram mount on the 07,on the2012 I have a 1/2" aluminum rod with 5/8 poly vynal tubing over it.drilled and tapped for a 1/4 20 stud and mounted a ram ball works better than the ram mount
