I've been building a turbo ZX14R for a while. It's now rideable and everything. Soon to get a MaxxEcu. I feel like I've earned the right to suggest parts to others looking to build a turbo bike since I'm nearing the 25 grand price-point for my build.
Here's what I've picked out for to build the simplest, most cost-effective, reliable turbo zx14. Feel free to disagree. I am happy to explain/defend what I have put on the sheet. I'll update the sheet as I learn more.
Sheet-
Head:
--Carpenter Valve springs
--Valve Spring Swap Tool (KAWI PART #57001-241)
--Valve Spring Adapter (KAWI PART #57001-1586)
--RBM Viton seals
--Cometic Head Gasket 0.030β
--NGK CR10E Plugs @ 18 thou
Clutch:
--SAE Outlaw Titanium clutch hardware
--MTC clutch fibers and steels (call to order)
--MTC billet basket
--MTC 2-stage lockup (Call to Order)
--Air/CO2 shifter to upshift under lockup load+high RPM
Block/case:
--SAE Outlaw Head studs
--SAE Outlaw oil system upgrade
--New Main Bolts
Rotating Assembly:
--Wossner Pistons 9.3:1
--Wossner 3/8β Rods (MUST SHAVE ROD BOLT BY BASKET)
--New Rod Bearings
--New Main Bearings
Timing:
--New OEM timing chain
--APE manual timing chain tensioner
Fueling:
--Injector Dynamics ID1050X
--Installation spacers
--HTP in-tank fuel pump/regulator
--PTFE AN6 Fuel Hose (E85 compatible indefinitely)
--5/16th EFI Hardline to AN6 Adapter (connects factory fuel rail to fuel lines)
--ΒΌβ vacuum line for pressure regulator
--Set Idle pressure to 43PSI
ECU:
--Route #1: Stock ECU. Some tuners can tune off just stock ECU. Example: Chris Boomstune
--Route #2 Stock ECU + PCV for map switch for different fuels
--Route #3 Stock ECU + PCV-PTi unit for tuners who do not tune solely off of stock ECU. Can add map switch for alternate fuel
--Route #4 MaxxEcu. Closed loop fuel adjustments. Traction control. Boost control. Launch control. Autoshift control. Flex-fuel. Engine protection measures.
Turbo:
--Route #1 RCC custom kit. Just turbo + oiling system + airbox block offs.
--Route #2 Scott Davis custom kit. Just turbo + oiling system + airbox block offs.
--Can also weld airbox if possible. Will lead to far less headaches down the line from degrading JB weld.
--JB WELD TANK WELD (to seal up air leaks and holes in frame. Reference instructions I supplied on what bolts and taps to use on install)
Suspension:
--Drag-valved rear shock (Ideally)
--Spring appropriate to body weight (Ideally)
--Reinforced Swingarm. Extended will be more manageable to ride due to wheelies from turbo torque.
Tire:
--Dunlop Q5S
--Dragmax
--Hookup
Gearing/Sprocket setup:
--Vortex 17 front (no rubber isolator)
--Vortex 39 rear (steel)
--3D chain with rivet master link
--SAE Outlaw titanium output shaft nut
--New sprocket nuts with nylon lock
* Last updated by: danmin on 11/5/2025 @ 4:07 PM *
