Confirmed. the 1:1 regulator is not sufficient for stock injectors on a turbo setup. I knew that but I was hoping the tuner would've mentioned that before having it for a couple weeks. I'm a hair jaded, but he could've had worse news to be fair.
He's throwing ID1050x injectors in. I usually hate to pay for labor. but the bike is 4 hours away from me. im not going to double my trip to save pennie's after cost of gas, food, sleep. Adding 8 hours to my overall trailering time to this bike is just out of the picture at this point. It's been on a trailer probably 500x longer than it's moved under its own power.
I'm moving away from the Microtech. For later E purposes. makes more sense to just bump up injector size now and sell the microtech to pay for them. If anyone is interested in the "Stage 2" portion of the RCC Stage 2 kit, I will be selling it for probably $1,000 + shipping. It's perfect. It's been tuned to perfection. Just need to tune your ECU through RCC (or have a local dyno tuner just tweak your tip-in fueling and part throttle fueling between 0-15% as well as pull 1 degree of timing for each pound of boost on the top end) and install this kit. You would need to ask RCC Richard for the Stage 2 airbox port, rubber hoses, 1:1 regulator. Saves you a few grand. I've probably invested 3-4k to get the MicroTech configured and well. Wish someone had warned me I was cornering myself with it...
Kit is perfect for anyone looking to only run a single fuel. As pump 93 is limited to 300-350whp (varies by tuner recommendation, Richard says 400whp)
* Last updated by: danmin on 9/15/2025 @ 7:06 PM *
