I installed these Rumble Concept LED flush mount turn signals and they flash too fast (my front stock bulb signal flashes like a strobe). I understand it's b/c the LEDs have such high resistance that control unit thinks a bulb is burnt out, so it initiates the frequent flashing warning code. I've read that to fix it, I need to install some resistors, get a relay, or put a new control unit from part store.
What do you know about each option and which would you recommend? If resistors, what wattage and how many ohms?? Tight on money right now so need cheapest way that works... I don't really care if it's a hackjob as long as it's safe and it works - no one sees the wiring under there anyway. :)
HELP!! Need bike in working order for tomorrow. Thanks!
