Im running ape valve springs on my 06 ZX14, i am wondering do the valve springs have to get shimmed or can i install them out of the box? Thanks
Created on: 08/02/19 09:30 PM
Baconboy
RE: Ape valve springs shimming
08/03/19 5:59 PM
https://www.youtube.com/watch?v=uMjpPcH_GtM
Heavy springs are installed to deter valve float at high rpm. For no other reason should they be used. As per wrinkle pressure in said direction stated in the video, there goes the acceleration of my valve guide wear. There goes the friction factor, meaning, it takes more oomph to the ramp up the cam to open the valve, effectively robbing HP.
https://www.youtube.com/watch?v=6dMldzy-768
Blue is the print. Good Luck just throwing them in out of the box!
