When it comes to cams, i remember hearing something along the lines of run two stock exhaust cams or is it two intake cams i cant remember anybody know i know one is bigger than the other. This is for a gen2 2017 zx14r se
Created on: 01/19/24 03:19 PM
thatZX14guy
thatZX14guy
RE: Cams
01/20/24 12:03 AM
This is out of my realm, 14guy. This is a tuner's question. I'm just a parts replacer/tune up guy. Might be good for top end use, but the idea of the power stroke is to keep it closed to its diminishing return. Open it too soon, you lost the grunt.
Seems like a quick in, quick out speed on the higher rpm range use. I could be wrong.
* Last updated by: Hub on 1/20/2024 @ 12:05 AM *
RE: Cams
01/20/24 8:07 PM
The old senior moment was not thinking of the embossed cam sensor pickup on the exhaust bump stick. Something like heating up the cam to weld a sweep bump on the cam's shaft, then reheat treat it? Pre FI you could get away with it. Today? Might try custom cams already with the sensor bump cast into it.
