If I recall, you already have removed the ABS system. If so, all you need is a spacer to replace the caliper mounting plate. I guess I'd grind that incorrect spacer out carefully so it fits.
I got lucky and my bike came without ABS. One of the few Gen2 bikes non-ABS. The rear sensor feeds the speedometer on these. I found out after taking my bike out for a spin and my rear sensor connector wiggling itself loose. Causes KTRC lights to flash and the speedo to read 0 MPH.
These bikes are kind funky in that way, because if you have either of the MAP sensors unplugged- KTRC lights flash, Throttle blade sensors disconnected- KTRC lights flash, front or rear wheel sensors unplugged- KTRC lights flash, Wheel sensors dirty or too far from the plates on the wheels that the sensors read- KTRC lights flash... All without any Error Codes showing on the screen when you check for them. This disables your ability to change power mode as well as traction control levels. I did a lot of troubleshooting these stupid KTRC lights during this project, if you couldn't tell..
The Front is used to determine if there is any wheel spin and maybe wheelies? Not sure what else it would be there for on a non-abs bike.
I found a spacer that gets rid of the sensor mount and rear caliper mount for $29.99 shipped to me. Weighs something like 50g. I think I will put the rear brake on the bike at some point. Right now I am just trying to simplify things and get it ready for my tuner. When it is time to live with it- It will need attention on the full brake system. I really need to find some good non-brembo front rotors for it. Only ones I found at $400 EACH.... Mine are so crazy warped, but you don't really use brakes on a dyno.
Once the bike is ready to take down to Houston for tuning, I will grab pictures showing the full air system setup, wire routing, vacuum hoses and breather hose routing, all the goodies. I am dreading the last part of this build, but I know it will pay off in the long run........
