Thread: Clunk from front end
Created on: 09/07/09 07:00 AM
Troppo
Troppo's Gravatar
09/07/09 7:00 AM
Hello all
Every now and then, I get a clunk from the front end when the forks compress under braking.
I have checked every nut/bolt/screw - all OK.
The front end (and back end) suspension settings are stock (as per the manual) - checked.
I am 76 kg - 165 lbs.
Any ideas?
Thanks
RE: Clunk from front end
09/07/09 7:55 AM
Two things:
1. Steering neck is loose on a hard braking stance is when you hear the knock. "Every now and then?" See, maybe a loose front end would knock on any brake mode. Loose is loose, right... ?Where do we go now?
2. Front suspension settings are too soft. You, "every now and then," bottom out and have this knock like mine, as I hit the transition from road to driveway. I have to stand up to add more shock rebound to my knees and the sound goes away.
Those are my two guess is, "every now and then" it may not be the two above and might be some inn else.
09/07/09 8:05 AM
I'm the same weight as you. I've never heard a clunk from braking but I had a few clunks hitting bumps and sudden inclines. I increased the preload and compression on the front and that solved it.
Troppo
Troppo's Gravatar
09/07/09 8:37 AM
Thanks both, will increase the preload and compression.
JESSE1212
JESSE1212's Gravatar
09/12/09 7:58 PM
fork oil dirty?
masszx14
burbs of boston, ma
09/22/09 2:54 PM
We discussed that issue here:
http://www.bikeland.org/board/viewthread.php?FID=27&TID=50087&set_time=
* Last updated by: masszx14 on 9/22/2009 @ 2:54 PM *
