Well done Bryan, great thread and your bike looks amazing.
You have not mentioned drag racing, but are you going to give it a shot and see how she goes?
Created on: 01/10/26 03:52 PM
OZrevhead
RE: Gen2 ZX14 Stage 2 RCC Turbo Build
09/25/26 7:50 AM
09/26/26 10:04 AM
This is a lot of money and hours of labor to confine the use to secret runs in Mexico but that alone would be good enough for me. Whata ya say, Bryan... LSR ? Drag racing?
bryan468
09/26/26 10:32 PM
Thank you for the compliments. I’ve had so much work to do to get the bike working decent that I haven’t had much time to mess with drag racing. I don’t have any tracks close by so I need to find some decent spots for 1/4 mile runs. The nice thing with the rolling runs is I can do the run and be slowed down in a matter of 10-15 seconds. Lately we’ve had a lot of rain here so I haven’t been out on the bike too much. I made some more adjustments to the 2nd gear boost table and I was able to run a 2.97 60-130 on asphalt so I was pretty happy with that. Most runs with a full tank of fuel are around 3.10 60-130 though so I think I’ve still got some work to do.
I’m tossing the idea around of installing a bigger turbo this winter. I suspect the wossner rods may not be strong enough so right now I’m thinking I’d like to go with some CP Carrillo rods, o ring the head, and redo the fuel system with a better fuel pump and 8an fuel lines. I just don’t know if I will have the time to mess with it this winter.
09/28/26 3:45 PM
Ah yes, TIME. You must be working still like me. I get home and i have time to do one ordinary task and then it's time to start getting ready for beddy. I could force myself to work on the bike more but then it's no fun. The new 14R sits here with zero miles put on it this year. I'm getting some rides on the new Hayabusa though.
Puck
09/30/26 11:29 AM
What would you be looking to turn it up to if you did go larger on the turbo? I researched internals a few months back and IIRC the Wossner's should be good for around 500hp, they are what I planned to go with for my relatively modest goals.
Bigger turbo is nice - not only does it make more power at same PSI of boost, but also can lower charge temps and the reduced exhaust restriction makes more power off boost as well :). The lag can be annoying though. My 57mm on a .83AR starts making boost at right around 3k, but isn't all in until 5500-6k. On the flip side, being a commuter that means I can ride it around off boost if I behave and still get decent MPGs and great manners.
bryan468
10/28/26 12:52 PM
I have started working on upgrading the fuel pump and I have ordered a new turbo setup from RCC. I have designed a fuel pump base and bracket setup that will work with an in-tank Walbro 450, 525, and E5LM brushless fuel pump. I’m hoping to start machining the parts for it soon. I’m planning to run the walbro brushless fuel pump which should support around 700hp on e85. I was considering using a walbro 525 fuel pump but I’m a little concerned about how many amps they take to run.
I have also placed an order with RCC for a new turbo setup. I decided to go with an upgraded GT35 turbo which is good for 750-800hp. I should have that in 3-4 weeks. Power goal is just whatever I can put down on the street. I’m guessing that will be around 600whp. Richard at RCC said they switch to CP rods at 600hp.
10/29/26 1:11 AM
I'm looking forward to seeing your 600 hp runs. Sounds like you have more work to do than just switching turbos and fuel pump. It's do-able over winter if you don't have too many other demands on your time.
