Created on: 02/24/24 08:32 PM
09/03/25 11:02 AM
There is oil on the 959's front valve cover and everywhere else, lower cowling etc. I just need to reseal the rocker cover, simple enough job in theory but in practice working on these things is a nightmare.
Take your time. Get a service manual and get a new gasket. Wipe the gasket surface on both parts clean so no oil has a path started. Use a good sealant I used the sealants that were recommended in the service manuals but they're insanely expensive and sometimes tough to find plus they'll probably be hard if you ever want to use them again. This will probably be very similar to replacing a ZX-14 valve cover gasket, there's a special sequence the bolts are supposed to be tightened in to get the valve cover settled in place flush.
The 14 has burned oil since new but otherwise solid.
I noticed by the second oil change, my 08 ZX-14 was using oil somewhere. The valve cover leak contributed a lot but I know in my heart, it still used a little oil between 2500 mile oil changes after I fixed the leaking valve cover. No big deal, it ran good. My Gen2 had oil changed at 600 so not a fair comparison but the oil level looked the same as when I first started it. The Hayabusa never used a drop of oil either. I don't know what it is with these 14s but like I said, if it runs good, that's all that matters. I believe I had to add oil before the valve cover leak was fixed but that was pretty simple.
05/19/26 9:12 PM
Latest edition, 2019 Ducati 959 Corse, fully loaded track build, it's in the paint shop now getting ceramic coating for the paint finish and should be delivered in about two weeks.
05/20/26 2:58 PM
I imagine the stomp grips will be removed for the ceramic coating. To be honest, I don't care for the look of stomp grips. Those are for goin' but they're not for showin'. I might look into what TechSpec has to offer....just as good and looks cool IMO. I've always used something to protect the finish on the fuel tank on my bikes.
05/20/26 8:28 PM
I don't care for stomp grips, you cover up a beautiful paint job with ugly plastic. I'll probably ask him to remove them before delivery.
05/21/26 2:11 PM
I've heard of sawing them off with tooth floss.
05/23/26 3:49 PM
05/24/26 6:22 PM
You could try rubber cement thinner as a solvent. I wouldn't use a heat gun but letting it sit out in the sun would probably help.
05/28/26 6:42 AM
Taking delivery of the new new bike Saturday morning if weather holds, I mentioned the stomp grips but the owner did not sound like he wanted to take them off. Will post pics!
* Last updated by: Kruz on 5/28/2026 @ 8:54 PM *
06/24/26 12:30 PM
The lovely Princess Amira aboard my 2024 Ducati V4 Panigale....
* Last updated by: Kruz on 6/24/2026 @ 12:31 PM *
