Since shiny chrome stuff is always good, I recently got a pair of chrome handlebar switch housings. After installing left side I checked switches. The hi-lo beam rocker switch seemed a tad off but OK, so I started bike to check hi-lo switch and ..no stinking fooling @*$+)*!)%^ headlight at all now. AS I took housing apart to see what the f, of course the hi-lo switch fell apart as it ejected a little spring never to be found. About that time I realized that exposed wire leads attached to the switches are very close to the chrome (metal) housing.
I suspect that one of the wires on hi-lo beam switch , prolly the hot wire, contacted my shiny chrome housing which now is a ground. Now at min. I need new hi-lo switch. I shoulda left it alone
Does that sound reasonable for why headlight no work now? Any ideas on how to insulate bare leads inside housing?
What about liquid elec tape or similar goopy stuff to insulate wires from metal housing? Or mebbe I oughtta shine the chrome part (pun intended) and re-install the non conducting plastic housing.
Ideas, advice, suggestions?
Next, if the above was likely to have caused the headlight to not turn on, what did it do? Now what?
Did it blow up the bulb, or mebbe just a fuse somewhere?
How or what to check to fix headlight? Where is fuse?
I'm stressing over the thought that bike may not be in proper working order when the urge to ride happens. That would suk.
After many rides and many years and just getting a ZX last year, I keep thinking about the comment on this forum made by ????. "After owning/riding a ZX14, you can never go back, and anything less just aint gonna cut it"
SO TRUE!!
If I didn't need stupid shiny chrome thingy, I would not have these issues.
dang it
TIB
