Good morning / afternooon / evening.
I am parting out my 2002 Kawasaki Ninja ZX-12R.
Pics attached.
Here's an updated list of parts along with prices!
No reasonable offer refused!
Air Intake Grill - $30.00
Battery Box - $50.00
Battery Jump Cable - $10.00
Blinker/Horn Switch - $40.00
Brake & Clutch Lever - $20.00 pair
Center Duct Cowling - $50.00
Chrome Arrow Front Turn Signals - $20.00
Chrome Battery Cover - $40.00
Chrome Front Brake Calipers - $120.00 pair
Chrome Front Rotors - $100.00 pair
Chrome Gas Tank Cover - $40.00
Chrome Rear Brake Caliper - $60.00
Chrome Rear Brake Caliper Bracket - $50.00
Chrome Rear Rotor - $40.00
Chrome Rear Sprocket & Hub - $50.00
Chrome Tank Cover - $40.00
Chrome Rims - $400.00 w/Tires and swap
Cigarette Socket Panel Mount Kit - $20.00
Clear Alternatives smoked rear integrated taillight - $60.00
ECU Computer - $200.00
Forks - $100.00 pair
Fork Assembly - $250.00 (does not incl. triple tree)
Frame - $600.00
Front Brake Master Cylinder - $70.00
Front Seat - $75.00
Front Sprocket Cover - $30.00
Fuel Pump - $150.00
Fuse Box - $70.00
Gauge Panel - $200.00
Gas Tank - $100.00
Gas Tank Shell - $120.00
Headlights - $150.00
Headlight Harness - $80.00
Heated Gear Cable - $15.00
Heel Guards - $20.00 pair
Inner Trim Plastic - $50.00 pair
Jump Cable - $10.00
Kuryakn Grips - $50.00
Lower Fairing Left & Right - $100.00 each
Lower Frame - $$25.00
Mirrors - $50.00 pair
Motor Oil Pan - $70.00
Polished Battery Cover - $35.00
Polished Swing Arm - $175.00
Power Commander III - $250.00
Power Outlet - $20.00
Puig Double-Bubble Windscreen - $50.00
Radiator Fans - $70.00 pair
Radiator Fan Thermo Switch - $50.00
Ram Air Tube - $75.00 pair
Rear Foot Pegs - $50.00 pair
Rear Seat - $75.00
Scott's Steering Damper - $300.00
Silver Brake & Clutch Levers - $20.00 pair
Subframe - $125.00
Starter Motor - $80.00
Stator - $125.00
Throttle Cable Housing - $30.00
Throttle Tube - $20.00
Upper Triple Tree w/Ignition - $50.00
Valve Head Cover - $50.00
Voltage Regulator - $70.00
Wire Harness - $80.00
PLASTICS
Front Fender - $50.00
Lower Fairing - $200.00 pair
Rear Tail Fairing - $50.00
Rear Seat Cowl - $70.00
Upper Fairing - $120.00
If you're interested in any of the parts listed above, please call me at 215-500-2366 or email seven114@sprint.blackberry.net
Thanks.
Seven
* Last updated by: KawKrew06ZX14 on 3/22/2011 @ 1:34 PM *
215-500-2366
seven06zx14@gmail.com
