Thread: 12 months service
Created on: 06/30/15 11:00 AM
OldMan
OldMan's Gravatar
San Jose, Sunny California
12 months service
06/30/15 11:00 AM
My beloved ZX14R will be 1 year old by the end of August. It has approximately 4000 miles. I will be doing my own maintenance and would like to know your feedback on what needs to be done. What I am thinking now are:
1. Replacing air cleaner with OEM
2. Replacing clutch and brake fluid
3. Checking bolts and nuts
4. Checking chain tension
Oil/filter has already been replaced. Am I missing anything?
1973 Suzuki GT250, 1976 Kawasaki KH500A8, 1979 Yamaha RD350, 1985 Yamaha Maxim700X, 1987 Kawasaki EX500, 1994 Honda CBR600F2, 2004 BMW R1100S, 2005 Kawasaki Z750S, 2003 Suzuki SV1000N
RE: 12 months service
06/30/15 11:38 AM
I can't think of anything else at only 4000 miles but your air filter is probably ok for another 4000 unless you've been riding in dusty or wet conditions. Pull it out and have a look.
OldMan
OldMan's Gravatar
06/30/15 12:15 PM
Rook,
Thank you for your feedback. I will check the air filter. It costs $55 so if I can use it for additional 4k miles that would be a big help.
06/30/15 5:36 PM
The Gen1 service manual specs evey 11.250 miles. I've gone 11,000 and it was very dirty. I don't think I ride in a dusty envirinment and I don't normally ride in the rain. I think 11000 miles will be too long for most bikes.
You could remove the levers and clean and lube. I'm updating this thread right now.
06/30/15 6:33 PM
You could lube your throttle cables if you feel like getting into it.
I guess you could take apart the the rear brake pedal linkage at the master cylinder and clean and lube. The OEM rear brake and shift pedals don't require lube, I don't think. ...maybe the rear brake pedal does?
* Last updated by: Rook on 6/30/2015 @ 6:33 PM *
07/01/15 6:02 PM
Get a service manual. Links to free downloadable copies can be found here. They list all the service intervals int he owners manual, and the same thing in the service manual. But specifications and instructions are int he service manual only for everything kaw doesn't consider "owner serviceable".
07/02/15 9:36 AM
Hope you haven't put all the plastics on yet, Oldman. Just as I posted this yesterday, the forum went out.
I decided to pull my air filter and have a look since I have a new one sitting here. This is it after 6,000 miles.
Here's a pic of one after 11,000 miles which is what the book suggests for service limit.
I think 6000 is long enough. 8,000 might be a bit too much. I tossed that 6k filter out and put in my BMC since we have pretty clean air here at the height of summer. I'll pop the fresh stocker in after a few hundred miles.
OldMan
OldMan's Gravatar
07/02/15 11:28 AM
Hi Rook,
Actually I haven't even started it yet. I have been busy traveling Now I am back and ready to tackle my ZX. I just ordered air filter from Bikebandit. Regardless I will need it eventually, I thought. I will get some brake fluid tomorrow. It will be a busy weekend. Have a wonderful July 4th!!
07/02/15 12:42 PM
Thanks. Gonna be a barn burner (I hope not) BIG fireworks at my uncle's place in upper MI. Get to see all the cousins and eat like a pig. I probably won't drink any beer.
* Last updated by: Rook on 7/2/2015 @ 12:43 PM *
