There’s going to be so many questions. I’m gathering information from our resident experts and Richard Peppler of RCC Turbos. I’ve already started building a FAQ list based on my own questions as I consider which system is right for me. I’ll edit in here on the OP as the list becomes more complete.
...and here it is!
Based on my conversations with RCC Turbos and a few other of you guys, here's what I came up with for Q and As.
Q: Should I go with an RCC turbo or a supercharger for my ZX-14?
A: You need a full exhaust with a supercharger, a turbo requires only a short pipe diverted out of the side of the lower fairing. Turbos benefit greatly from an intercooler because the forced induction is caused by the exhaust. The power required to generate induction by a supercharger is supplied by the engine. Even so, it appears an intercooler is used even with a supercharger, they create more heat than a turbo does. A supercharger setup will probably be heavier than a turbo too. Superchargers are often favored over turbo for low end performance but struggle with higher rpms, or are limited where a turbo excels. Superchargers introduce parasitic drag on the engine. A turbo probably restricts exhaust flow to some degree. Both produce a net gain in engine power but it seems the cost of inhibiting exhaust flow is lower than the cost of taking power directly off of the engine. The TTS Supercharger in development at the time I’m writing this is priced competitively with an RCC stage 1 or stage 2 turbo kit. The top package offered by RCC Turbos is considerably more expensive than the TTS supercharger now produced for the Hayabusa. To sum all these thoughts up, turbos are usually favored for racing applications and superchargers for street performance. …but read on because it looks like the RCC turbo measures up equally well in ZX-14 street applications to the TTS supercharger.
Q: How much lag is there with an RCC turbo on a ZX-14?
A: On a ZX-14, there is basically no lag with the Garret GT 2871R ceramic ball bearing turbo included in the RCC kits. The turbo is making 1 psi of boost at 1500 rpm, just off of idle. Target boost is achieved at 3500 rpm.
Q: Between the RCC Turbos Stage 1, Stage 2 and Stage 2 Ultra, besides the equipment included in the kits, are there differences in the turbo itself?
A: All three kits contain exactly the same turbo. If you have some other turbo you’d like to use, they can do that.
Q: Can the Stage 1 kit be upgraded to the Stage 2 Ultra?
A: Yes.
Q: Will I save money by purchasing the Stage 2 Ultra kit rather than the Stage 1 and then upgrading the Stage 1 to the Stage 2 Ultra later?
A: If the Stage 2 Ultra is what you want, you will save some money in the long run if you buy that from the start.
Q: Are all components of RCC turbo kits bolt-on?
A: All except the fuel rail which requires drilling and tapping two holes inside of the air box.
Q: Can the RCC Turbos Stage 2 Ultra kit be run without all of the engine mods required such as HD connecting rods and turbo pistons?
A: Other than secondary butterfly removal, any RCC turbo kit can run on a completely stock engine with the 4 to 6 psi waste gate spring. A thicker head gasket, high performance head studs and valve springs and mods to improve oiling are the first engine build steps for higher boost.
Q: Will it be necessary to alter any ECU parameters such as timing or rev limiter to run the turbo safely?
A: RCC offers a specific flash for the ZX-14 that alters the ignition timing and sets up an over rev safety factor. Typically we raise the limiter a bit, depending on how the engine is built or not built.
Q: Is it possible to edit the RCC flash using Woolich software?
A: You can but there is probably no reason you would want to do that, the RCC flash was created specifically to work reliably and safely with the RCC turbo setup. If you have reasons to adjust any parameters of the RCC flash, that is possible using Woolich software.
Q: Does the RCC flash adjust fueling requirements of the RCC turbo?
A: The RCC flash does not address fueling needs. A Power Commander 5 with PTI seems to work perfectly for the Stage 1 kit. The Stage 2 kit includes a secondary ECU that will monitor boost pressure and adjust fueling as required. If it’s necessary to adjust fueling for reasons other than boost pressure, you would need to use a closed loop tuning system and a standalone ECU such as Maxx ECU or use Woolich software and related equipment to adjust your own custom mapping.
Tuning for turbo is something I still have lots of questions about. I’ll update this info as soon as I learn more. For now, it looks like the RCC flash with secondary ECU or the PC5 with PTI are both excellent and easy to use options.
Q: Are carbon fiber wheels safe to use with your turbo?
A: There have been problems with carbon fiber wheels cracking. If you use them, it’s probably wise to go with one that’s designed for use with turbo.
Q: What is the weight of the Stage 2 Ultra kit and the intercooler?
A: The shipping weight is 50 lbs or slightly less. The parts removed to install the kit weigh at least 40 lbs.
Q: If I prefer the look of separate exhaust and dump pipes to the single exit of the RCC turbo, can I have that?
A: The combined waste gate and exhaust pipe exit designed for the RCC kit requires no fairing trimming but the RCC pipe can be removed from the exhaust port and the blowoff valve. Separate exhaust and waste gate pipes, could be fabricated. The RH lower fairing would also need to be trimmed to fit separate pipes.
Q: I also prefer the look of the air filter sticking out of the LH fairing. Is this possible with the RCC kit?
A: The RCC kit was designed to minimize the visibility of the turbo but a longer filter may be used provided it fits the diameter of the turbo intake port. You also may need to trim the LH lower a bit differently to fit a filter other than the one that comes with the RCC kit.
Q: Can an aftermarket exhaust with muffler be used with an RCC turbo?
A: Aftermarket exhausts are typically too small and restrictive, RCC Turbos offers exhaust options including one with a carbon fiber can muffler with slash cut exit. They also have a shorty shaped somewhat like an M-4 Retrodrag muffler. Both appear to be larger in diameter than typical aftermarket exhausts.
Q: The intercooler that comes with the Stage 2 Ultra kit has a heat exchanger that is positioned in front of the radiator. Doesn’t this block airflow to the radiator and create extra heat that impacts the effectiveness of the engine cooling system?
A: The heat exchanger is only trading heat when the turbo is generating higher boost. This is at higher speeds. Low speed and normal street riding engine temperature isn’t effected by the heat exchanger.
Q: Is there an advantage to using water/meth injection along with your intercooler?
A: No, not really. [I’ll be looking more into water/meth injection in the future. From what I’ve heard, it not only reduces engine temperature but it might even produce more power].
Q: Is oil leaking from the turbo when the bike’s shut down something I'll have to live with?
A: The ZX14 kits we sell come with a 1 psi check valve so no oil leaks past it on the feed line when the engine is shut off, and we use a mechanical scavenge pump so no oil back up from the drain side either
* Last updated by: Rook on 3/22/2025 @ 4:13 AM *
