Pull your secondary plates or adjust your riding. I recommend both.
I'm with Mav
IMO of course,,,, Flies ,,, take them out. If you have not sprung the cash or don't have it for a flash take them out, it's Freeee. Half of your safety mode is now removed. No brainer Sweeeeet.
When I say half you must know in safety mode timing gets pulled. Sorry no cheat for this. Flash or live with it. If you guys don't hammer throttle off the line every start it means nothing to you and you will love and enjoy the bottom end punch from the flies out mod, promise.
Also Dyno #'s showing more power with flies in are just that Dyno #'s. They do Not take into account the cooling effect of the Ram air. Lee pritchard has run back to back testing. His fastest runs, FLIES OUT.
Nasty according to Romans and Ivan the older 4-1 Akrapovic system makes the most low to mid range power. Well let me restate that, the most mid range for sure.
Yep, A war I don't want to get into but BacK to back testing with both Beast Bike and mine, was Akra for the win. My bike made 2hp up top which means nothing but midrange was a Wow. Our tests proved same results as Ivan #'s on the dyno. Street testing proved the same results.
Easy fix. Take out secondary flys. Get 1/4 turn throttle insert.
This man speaks the truth. Mad Max afterwards. Lots of fun.
* Last updated by: Romans on 10/28/2014 @ 8:15 AM *
