... Were my last 2 oil changes. At 1906, I started to feel the shift quality go off song and finally got around to changing the oil. I could not ride the bike any longer. I guess I am that sensitive or tuned-in to the bike.
9464 miles is what the speedo reads. I must have put a few hundred miles on the bike in the last few days, running around trying to find two bikes at a dealership and speaking to someone about ECU flashing, trying to catch him as his shop. 3rd time was the charm.
If the drive chain were loose, I would notice poor downshifts. But this was not the case. I don't know about you, but this bike will tear up the oil in less than a thousand miles... Shift quality wise.
I cannot believe I am looking back at the mileage and when I dump the oil, it is when that gear box shifts like sour green grapes. Last change before that 1040 sign-off, happened at approx. 700 miles, and I had to change the oil that soon being the shifting just goes away. Hard to believe I know.
Took a ride to get a few OEM's, being I ran out of filters. I thought I'd wait till the weekend to dump the oil, but I guess I am just too anal and did not want to wait and sit on that dentist chair without the assistance of novocaine.
Just came back from tearing the filter open. NADA! If you only knew how hard I beat this bike on the street. I leave before the starter motor stops spinning on a cold engine [every single time]. No sitting around waiting for the bike to warm up. I am moving well under 2,000 rpm, keeping the revs below that number, while the clutch is being pulled in for stop signs. Kind of like a fast idle.
By the time I am on the highway on-ramp, the dash has struck one temp bar. Where is that bearing sheer? Where are the transmission dogs or window slots? Didn't I miss a shift or two, waiting for the gear box to be all chewed up, or say slamming 1st gear on occasion? The magnet picked up zip. Sure, I can see super tiny aluminum chips, but they sure do not look like they are coming from the rod/case bearing inserts. More like out of the threaded holes all inside the crankcase.
Almost 10K of daily abuse since day one and this is one fine running machine. Crisp rasp of the throttle on downshifts, it sounds so toned on the blip. I'm so aggressive in traffic, cars become dots in the mirror or more they are a half a mile away I keep the throttle on to get away from these speeding idiots that bunch up passing each other, changing lanes swapping back to the other lane and went nowhere... For what?
I've poured in straight syn, 50/50 mixes of different weight oils. Old oil or diesel engine oil, it does not matter. No engine damage. Just a transmission that no longer shifts with 4 quarts of fresh, sheer-less oil. WOT a blast this bike is. Unending power on tap. I could almost start dancing.
* Last updated by: Hub on 11/11/2009 @ 6:13 PM *
