Thread: Rear Sprocket side out ?
Created on: 11/19/15 03:06 PM
chrly
chrly's Gravatar
11/19/15 3:06 PM
My stock 2013 ZX14 rear spocket is slightly offset. My question is to which side of the bike does the relieved side go ? It was originally facing the clutch side of bike . It would make about a 1/4 inch offset if placed teh wrong way.. unless I am way off base..
* Last updated by: chrly on 11/19/2015 @ 3:07 PM *
RE: Rear Sprocket side out ?
11/19/15 4:01 PM
I'm going to assume you had the rear wheel off. Go look for the internal collar in the garbage can or steel barrel you left the rim on... I'm a little confused as how this lineup is moving in or out? It all bolts together one way... unless you are missing parts like part number 42036-Sleeve-RR Hub.
http://www.kawasakipartsnation.com/oemparts/a/kaw/50aa38c0f8700226a4146726/rear-wheel-chain
chrly
chrly's Gravatar
11/19/15 4:46 PM
. I guess I did not explain it very well. If you look in the link at the sprocket ( 42041) , you can see that teh side facing out , which shows in the diagram, is relieved. If you turn that sprocket backwards , it is flat and it will it will move the teeth in towards the center of the wheel a very small amount. According to the diagram, the relieved side faces out which is what I had, just wanted to be correct.
Thanks for the link.
* Last updated by: chrly on 11/19/2015 @ 4:46 PM *
11/19/15 6:16 PM
The lettering goes out..facing you.The teeth track will be out just a bit further than the main portion of the sprocket.The totally flat side goes inward.
* Last updated by: Grn14 on 11/19/2015 @ 6:21 PM *
11/19/15 6:16 PM
Stamped side outwards my friend!
11/19/15 6:36 PM
Same on my 08. the number 41 (I believe the gen 1 has a 43 tooth so 43 for you) faces out.
This is a gen1 mind you. You see the 41 stamped a little past 4 o'clock. Teeth are set outward, nuts are against a recessed surface.
* Last updated by: Rook on 11/19/2015 @ 6:36 PM *
Jaidigan
08/23/21 12:11 AM
You actually can order the all the spare parts of ZX14 from China. Their market is still supporting old model spare parts on essayontime you can see people are not getting their demanded bikes parts but China is still producing them.
robertpatton09
02/02/22 10:03 AM
All of the parts for a Kawasaki ZX14 manufactured in the last 6 years can be purchased directly from Kawasaki. As a matter of fact, the average list price for all of the parts is $9,143. You can view the price list of British Wire by visiting this website. BritishWiring carries an extensive line of wiring harness for most classic British cars and motorcycles.
robertpatton09
02/07/22 4:41 AM
All of the components for a Kawasaki ZX14 synthetic within side the closing 6 years may be bought at once from Kawasaki. As a count of fact, the common listing fee for all the components is $9,143. You can view the fee listing of breaking news with the aid of using touring this website. British Wiring incorporates an in depth line of wiring harness for maximum traditional British automobiles and motorcycles.
maggot
03/07/22 3:34 PM
Guys alright but everything aside,educational news be careful out there alright? I have a friend hospitalized for months now and I’m so scared now.
