Hey Tahoe...I found lowering the shift pedal even one notch ruined my ability to shift.Believe it or not.Doesn't seem like it would,since it is adjustable...but...it wouldn't shift up from first,not without me having to stick the upper arch of my foot under the pedal and lifting....forcefully.It wasn't gonna work for me.The brake pedal...I think you can possibly loosen the keeper bolt,maybe,and adjust down a bit...not sure.If you DO lower the throw,you'll need to readjust your brake light switch by turning it at the top where the wire goes in.(remove the heel guard...then you can reach in there and turn by hand).I'm curious...if you have short legs,why would you want to lengthen the reach to the footpegs?
* Last updated by: blue07 on 10/12/2011 @ 1:04 AM *
