what size spark plug socket is needed? and what is the NGK spark plug part number for our bikes?
Created on: 01/31/11 07:20 PM
Jeff01ss
RE: spark plug socket size
01/31/11 7:53 PM
CR9EIX is the iridium plug($10.50ea) cr9e is the traditional plug($5.50ea) @ motorcycle superstore
they require 5/8 socket
* Last updated by: scottjkyl on 1/31/2011 @ 8:16 PM *
01/31/11 11:09 PM
The book calls for NGK CR9EIA-9 and the only tool to use to remove them is the stock spark plug socket. Use a gear wrench to turn it. 14 mm gear wrench I was told.
I've only had the one on the right out because the others are unbelievably hard to get at. You'll need the tools mentioned here.
02/01/11 4:33 AM
rook thats what i saw too but look here at the fitment chart from ngk websight for that plug
NGK - CR9EIA-9 Automotive Fitting: We do not have an automotive fitting for this part in our database. Non-US Automotive Fitting: We do not have a non-US automotive fitting for this part in our database. Non-Automotive Fitting: Category Make Motor Model Motorcycles, Minibikes, Mopeds, Scooters KAWASAKI 2005-2004 ZX1000C NINJA 1000 Motorcycles, Minibikes, Mopeds, Scooters KAWASAKI 2006 EX650R Ninja 650 Motorcycles, Minibikes, Mopeds, Scooters KAWASAKI 2007-2004 ZX-10R NINJA 1000 Motorcycles, Minibikes, Mopeds, Scooters SUZUKI 2007 GSX-R1000 1000 Motorcycles, Minibikes, Mopeds, Scooters YAMAHA 2003-2002 YZF-R1 1000
02/01/11 8:46 AM
Hm- I wonder if it was an oversight. I would pull a plug and look at the part #.
People do use different plugs than OEM but I've heard there is nothing special about plugs, just go with stock plugs.
Never changed plugs myself but that's a common enough procedure that we would have prolly heard if the spec OEM plug did not work.
???? I'd pull a plug and look at the part # but I'm sure there are many possible plugs other than OEM that could work.
You know who would know this 4shore??
02/01/11 9:04 AM
ok kawasaki parts house says oem is the CR9EIA heres the link
Kawasaki : ZX1400C8F Ninja ZX-14 (2008) <<-- Pick New Model Change Assembly: Tag Description Req Price 21007 SKU: 21007-0066 ROTOR 1 $26.32 21171 SKU: 21171-0005 COIL-ASSY-IGNITION 4 $96.20 26031 SKU: 26031-0360 HARNESS 1 $64.58 59026 SKU: 59026-0028 COIL-PULSING 1 $99.02 92070 SKU: 92070-0014 PLUG-SPARK,CR9EIA(NGK) 1 $8.06 92153 SKU: 92153-0549 BOLT,FLANGED,8X23 1 $4.68 92153A SKU: 92153-1293 BOLT,SOCKET,5X12 2 $2.97 92171 SKU: 92171-0524 CLAMP 1 $2.97
* Last updated by: scottjkyl on 2/1/2011 @ 9:08 AM *
Jeff01ss
02/01/11 12:04 PM
i can mail u mine as long as u mail it back lol
02/01/11 12:18 PM
PM sent.
Jeff01ss
Jeff01ss
02/13/11 3:10 AM
Thanks again DogoZX! They were ALOT easier than expecting! Only took about 30 minutes, cause I already had the plastics off. Mine were in bad shape. Much more snappy now, can't get on it hard yet cause the roads are still cold and salt covered.
* Last updated by: Jeff01ss on 2/13/2011 @ 3:12 AM *
Jeff01ss
02/13/11 9:26 AM
No problem... glad to help.
