Thread: 14R new wheel combo
Created on: 04/19/14 01:44 PM
lacker
14R new wheel combo
04/19/14 1:44 PM
Put these Gen 1 wheels on for a different look...What do you guys think??
* Last updated by: lacker on 4/19/2014 @ 1:45 PM *
RE: 14R new wheel combo
04/19/14 5:56 PM
I LOVE EM!!!!
Bit heavier than Gen II, but love em!
04/19/14 5:56 PM
I LOVE EM!!!!
04/19/14 8:53 PM
Look sweet...I can only suggest....BST's...sorry.With ceramics bearings...You won't believe the feeling factor with these...I minimised any feel with em...but reality is....amazing...really amazing;)Kinda like having ABS....way nice;)!Never thought ABS could be so...approprite on the 14.I was wrong...very.Depended on it several times now...Transforms your confidence level in untold ways.
* Last updated by: Grn14 on 4/19/2014 @ 8:56 PM *
04/19/14 8:57 PM
Beautiful 14R BTW....Trust me...when you NEED that extra stopping power...they come through wonderfully!And NO frontend wiggles;)Believe me...at speed...and an emergency stop approaching,slabbing the brakes WILL save you in so many situations...You'll be VERY thankful you can slam her all the way and give yourself time to react much better.Skids in emergencies REALLY suck.I 'tied' to lock mine in wet roads several times at speed....no lock...just a very controllable stop...nothing like having a rear or front lock and slide.....warning...that'll get ya killed QUICK!
* Last updated by: Grn14 on 4/19/2014 @ 9:11 PM *
lacker
04/19/14 10:37 PM
Thanks for the replies,and from I hear they are about 3LBS heavier than the GEN2 rims... I really like the look....I also installed a set of Votex Rear sets,annitori quick shifter...More to follow..
Cblast
Cblast's Gravatar
04/19/14 10:49 PM
Hey bud! Your bike looks freakin nice. I thought I should point out, have you looked at how your rear brake line is kinda getting pinched by the heel plate and the other line on that side? If you loosen off that banjo bolt, you can re-position those lines so that it isn't being pinched. Just noticed it and thought I would point it out. That brake line shouldn't be pinched at all just from a function standpoint. I ran into the same thing but was able to find a happy place for it. Cheers man!
14 NATION
Disciple of the 14R
Vincit Qui Patitur
PredatorRaceTeam@gmail.com
Cblast
Cblast's Gravatar
04/19/14 10:55 PM
Note, the larger of those two brake lines (the one to the reservoir) can be rotated slightly and it stays sealed, its a clip ring insert fitting. And when ya loosen that banjo bolt it might leak a little fluid, just use a rag there so as not to leak it in your componentry. May have to top up the reservoir when done but you shouldn't lose much at all if ya keep the cap on the reservoir while that banjo is loose.
* Last updated by: Cblast on 4/19/2014 @ 10:55 PM *
14 NATION
Disciple of the 14R
Vincit Qui Patitur
04/20/14 12:36 AM
Sweet looking 14!
04/20/14 7:30 AM
First thing that I thought before I even looked at the pic. Looks nice and I know the bike has pleanty of power to spin a Gen1 wheel but I'd go with a green vinyl stick on and stick with the light wheels. Does look mighty sharp though especially with the Brocks emblem.
pis of squashed downspout, step 15
A slight pinchin that downspout shouldn't hurt performance but it's nice to have it unsquashed. Cblast's idea is a more tidy solution here's what i did.
My OEM brake line was routed behind behind the downspout at the factory (don't know if they continued this with the GEN2 but thew Gen2 looks like the same brake line and MC as the gen1). I turned the brake line so the there was more space between the downspout and the brake line. The nub on the OEM brake line is there there for positioning but it the brake still works if the nub is not between the nubs on the master cylinder. If you go to after market lines, those don't even have a nub.
04/20/14 1:16 PM
like this
lacker
04/20/14 10:02 PM
Thanks for the info guys....Will take a look at this soon...Still needs a little cleaning on the Chain side(White chaine grease). Cheers
darkarcher
darkarcher's Gravatar
Cincinnati, Ohio USA
04/22/14 10:10 AM
Is that a CT single or dual? What effects did you feel on you low and mid range?
2020 on the way!!!!!!
lacker
04/22/14 7:58 PM
darkarcher,its a Ct Single. The Power feels smooth through the entire range.Really seems to go into a time warp after 7k!!
