I'm interested to see if anyone's had experiences in moving from the stock 70% aspect ratio to a 60?
All the best-
2008, Midnight Sapphire Blue, Muzzy M14 full-system, HealTech iQSE, Schnitz Racing ECU Flash
Created on: 06/29/17 07:47 PM
44magnum
RE: 120/60 vs 70's
06/30/17 11:27 AM
I never even thought about that but if the object is to lower the front to improve handling, you also would have a lower contact patch and that might be why nobody does it. Also a little less clearance for cornering and bumps.
44magnum
RE: 120/60 vs 70's
06/30/17 5:10 PM
I guess I would, too. There is quite a dif in price between a 190/50 and a 190/55 and more for a 60. It might be $15-20 for a front. The 60 would be about 12 mm lower. I don't see how it could have as much outer tread. Personally, I don't need that on the front but I do need the clearance. 12 mm could make a big dif for scraping.
* Last updated by: Rook on 6/30/2017 @ 5:11 PM *
suzy1052
44magnum
