Bought a fan off ebay last night so gonna attemp to do the dual fan set up on the 14.
Will let you know how bad I screw it up.
Later == Bobby
Created on: 06/10/09 05:34 AM
lytnin
jessejames4
BadinBlack
Paladin
Sharkey
RE: fan again
06/12/09 8:01 PM
I get a lot of heat on my right shin at stops or moving slow. I wondered if the second fan (which would go on the right side) would help with that?
BadinBlack
RE: fan again
06/13/09 12:11 AM
I am open air is no change in dash bar readings. I match, Paladin. I match leg warmth is same direction out is hit the hot air hits you first, being right behind it. Soooooooooooooooooooooooooooo...
WATT does that tell you about a fan and then second guess the engineering, sitting on a heat sink anyway.
Sharkey
RE: fan again
06/13/09 5:54 PM
How about putting the fan in reverse at stoplights?
