Thread: torque wrenches
Created on: 10/26/11 08:05 PM
torque wrenches
10/26/11 8:05 PM
I know you can spend a great deal of $$$ on torque wrenches. I have cheapies. I never caused any damage using them. Recently bought $14 on sale torque wrench. 20~200 in lbs. I used it to do a 90 lb torque today. I had previously used my beam 0~75 ft lb torque wrench to do a 5 ft lb pre torque. That should be the same as 60 in lbs. WHen I checked my 5 ft lb torque with the new torque wrench, none of the bolts moved until 90 in lbs. That is 33% more torque than my beam tq wrench was indicating.
I know torque wrenches are always most accurate closer to the middle of their range but could they really be off by that much?
Which wrench should I believe? Not like they are both in the same ballpark.
* Last updated by: Rook on 10/26/2011 @ 8:08 PM *
alg8er
alg8er's Gravatar
RE: torque wrenches
10/26/11 11:03 PM
The advantage of getting a brand name torque wrench is it can be calibrated. I use a Snap-On, and get it calibrated whenever I can catch the snap-on guy. One tool I don't think you should go cheap on.
RE: torque wrenches
10/27/11 4:34 AM
I haven't seen a Snap-On truck since I had my own machine shop. Still have some tools though. I remember paying "on credit" when I first got started, a little bit each time he came by the shop. Some things were way better back in the day. Actually, a lot of things.
I have a little beam torque wrench, that I use on things like pan bolts etc. The dial plate will rotate so you can look at it from the other side.
I have a medium ratchet torque wrench, and a large one. I really should calibrate them, but don't use them enough anymore to remember to do it.
alg8er
alg8er's Gravatar
RE: torque wrenches
10/27/11 10:19 PM
I have a buddy that's a car mechanic. He calls me when the Snap-On guy shows up. If I can get there fast enough he'll do it.
here's a video to check your wrench's accuracy.
you can try here to see if someone locally can calibrate.
calibration search
* Last updated by: alg8er on 10/27/2011 @ 10:22 PM *
RE: torque wrenches
10/28/11 4:13 AM
I can calibrate my own, I just don't ever seem to find a reason to do it. I hardly ever wrench anything anymore.
alg8er
alg8er's Gravatar
RE: torque wrenches
10/28/11 9:45 PM
privateer; I'm with you. In fact the bike is in the shop, torn down as I type. Every once in a while either an emergency, or something simple comes up that I can handle. Nice to have a calibrated torque wrench, especially with my ham fists.
RE: torque wrenches
10/28/11 10:38 PM
thanks alg8er. I do not think my TWs can be calibrated as shown in the vid. They each cost much less than what a pro calibration would cost anyway. The video shows a great, simple way to check your tprque wrenches so you will at least know if and how much they are off.
seno
seno's Gravatar
RE: torque wrenches
11/08/11 1:37 PM
Thanks for the video, I'll call the snap on guy....
samuel1352
samuel1352's Gravatar
Central Valley, Calif
RE: torque wrenches
05/25/12 11:15 AM
I have a Craftsman deflecting beam, and two click-type Craftsman torque wrenches, one inch-lbs and the other foot-lbs. I just bought a half-inch drive foot-lb click-type wrench at Harbor Freight on the cheap. Plan to only use that one for checking big torques like axle nuts, etc. I think that in general, click-type/break-away torque wrenches are more accurate than deflecting beam ones. I set the lug nut torque on my wife's truck with the deflecting beam wrench, and plan to try the new half-inch drive wrench on her lugs to see how close it is to the deflecting beam wrench.
1973 Honda CB350F, 1971 Honda SL350, 1976 Triumph Bonneville, 1978 Harley Low Rider, 1999 Kawasaki Concours, 2008 Suzuki Bandit 1250S and 2011 Kawasaki ZX-14.
KoflaOlivieri's Gravatar
RE: torque wrenches
05/25/12 12:18 PM
I purchased mine back in the mid 70's, still working great. I always loved Craftman tools.
That is the reason why I purchased my first Snap-On torque wrench. The Snap-On guy was also a customer, owned one the first 1987 CBR-600's, he also visited the shop once a week so if there was a problem he was always accessible to exchange our tools.
NINJA ZX-14 MotoVlog
