Well...I don't recall saying anything about a head gasket.I doubt if it's that.You'd have water in your oil.Looks to me like MAYBE that overflow could have something lodged in it(or kinked under there somewhere?).Instead of heading over to the reservoir bottle,it's squeezing past the upper hose connection.Plenty of pressure when she's warmed up to operating temps.You could remove the reservoir connection end of the overflow line(the top one) and see if you can blow some air through there...just enough to see if it's okay.Still looks to me like that upper line has been replaced.Might be squeezed above the engine head there somewhere.
Bubbles from air pockets in the lines HUB...not "head gasket"...
I think if the cap was somehow faulty,there would be a film of coolant residue on that filler neck under the lip.None there that I see.I know with mine...that cap can be a bit finicky.It doesn't always just "slide locked" like yer automobile!And it can seem a bit "too tight"...that's normal(at least mine is like that).
Ya'll gonna scare him to death.Nothin wrong that I see...except the overflow line is not working okay...maybe low coolant and extra pressure build up from running low.I say...fill er up,run.get er warmed up good...check that filler area for leakage at the overflow line connection.Make sure there's no air pockets in the radiator line circuit(per the manual).And RIDE!
Fill...start...let idle to operating temp.Check radiator area for leaks...holes...anything.Let er run even if she comes up to say one or two bars....it won't hurt the engine.Check for leaks.You mentioned "aftermarket" stuff on there..looks like a radiator guard on there.MAYBE...that's not the original radiator...could possibly be a REPAIRED unit...might be leaking someplace on it.Just a thought.IF it overheated because of low coolant,it would create greater pressure than normal.It could possibly squeeze out of those fittings at the filler neck there.But there'd have to be an obstruction in the lines.Otherwise,it'd go to the overflow bottle.Your coolant would get sucked from the reservoir to fill the radiator.You say..."the levels are fine in the reservoir".Okay...so I think there's a blockage somewhere.
I think that upper line is pinched under the frame and engine somewhere.You could check the reservoir bottle when she's good and warm...see if she's pulling coolant from it.(while running).
Here's a thought...is that cap a stock zx14 cap?Possibly it's an aftermarket cap....might not be opening up correctly OR maybe blocking that lower and upper feed line hole(s).(the ones at the filler neck).
Lots of guys "think" the bike runs "hot".It doesn't.It's normal to have "high" appearing temp bars going.Depends on your riding,or sitting in traffic.Maybe this guy figured he'd replace the cap with something rated differently.IDK.
I'm lookin at your pic there...the one with the cap off.That upper line IS NOT STOCK.AND,there's NO connector ring on it to keep it from leaking.Something's not right there.Also..that pic shows the fins in there...the manual shows virtually the same pic,but the fins are going across and level with the upper portion of the radiator top.NOT up higher than the filler neck area.At least that's what it appears to be doing to me.It looks vertical,not horizontal.Something's not right .That radiator has been messed with somehow?.
I just did a bit of comparing in the parts fiche.The 09 zx14...don't know what year yours is..the radiator has a single fan,and the last four numbers in the part number are NOT the same as the ones for the 09 CONCOURS(which has TWO fans).The description numbers are the same for both radiators however.So that tells me the OUTSIDE design is still the same between the two models(the last four numbers suggest a "change" of something)They are not the same on the 14 and Concours..You don't suppose he installed a Concours radiator in there do you?Having TWO fans suggests that Kawasaki addressed the "heat problem" on the Concours(which was pretty serious according to the owners)...and MAYBE they changed the internal core volume as well.Still think that pic is showing a "different" core.I could be full o' hooey...but it does look different to me.Do you have TWO fans?
08 Concours...cap assembly..#49085-1066. 07 zx14...cap assembly...49085-1070 P1.1....09 zx14 cap assembly...49085-1066...same as the Concours.For whatever it's worth.USUALLY...a guy will buy a Rad guard to AVOID rock strikes.However,some guys won't get one UNTIL their radiator gets already damaged.Maybe he replaced your rad with a different one,and added the rad guard for insurance?That pic(the upper one)sitting just under the hot wind cover...is that a second fan on there?Looks like a fan housing to me.The zx14 fan is on the right side.
IF you DO have a Concours radiator on there...and the guy filled it per the zx14 amounts,it is possible that there wasn't enough in there to start with.It could overheat,and the reservoir levels would probably be "off".Assuming it IS a Concours radiator...filling it to the Concours levels should correct any problems...it should work fine as long as it fit in there okay.But it might not.Higher volume and flow could perhaps somehow throw off the ECU's settings for temp and such.IDK.
WHEEEEE!!!!from a simple hose leak...TO THIS!!!! ![](/images/emoticons/laugh5_smilie.gif)
08,09 Concours radiator...last four numbers are 0107...zx14,08,09...last four numbers are 0080.Something's different.My guess...core volume.
* Last updated by: blue07 on 4/30/2011 @ 5:19 PM *
