Again, when that wheel comes up, it's sending energy to both those forks 'equally' is my guess and things being equal in nature, that fork acts as one fork as the axle locks them both together as one.
Same thing I was thinking.
Carrozzeria is the pioneer of forged aluminum wheels for motorcycles and the Carrozzeria V Track Forged Aluminum Wheels are lighter, stronger, more durable and longer lasting than any other motorcycle wheels available on the market.
Even though magnesium or carbon fiber wheels are lighter, when you think of your safety and durability, none of them even come close to Carrozzeria forged aluminum motorcycle wheels. Just ask any professional about the benefits of forged aluminum.
Carrozzeria forged aluminum motorcycle wheels are 20 - 40% lighter than stock depending on model. Reducing weight on a motorcycle will always make it accelerate, corner and brake better, but some weight reductions are much more valuable then others. Motorcycle weight can be classified in two ways: sprung or unsprung and rotating or non-rotating. Wheel weight is both unsprung and rotating, which is the most significant weight to remove.
Please Note: Rear wheels use Kawasaki bolt pattern sprockets:
^^same goes for the Carros I have for the 14. You can stay with the OEM sprocket and rear rotor and use OEM bolts and nuts. Front has a 6 hole pattern with smaller bolts (do not use OEM torque spec ...smaller bolt shank, aluminum threads....snap or stretch/strip hazard--rather stupid design IMHO--my only complaint). I believe it is the same pattern and bolt as used on a CBR. You'd need new front rotors. Carrazzeria 13" rotors are VERY light. They have no spec for warp but one of mine was out of spec when brand new by Kawasaki standards. No problem with handling. YES problem with harder braking....got a loud groan for quite some time. Not so bad now. They claim you should use organic compound pads because the scintered material is alloyed into the rotor. I had used scintered pads....probably took a long time bed in which was part of the groaning problem.
58 cycle had a great deal on CZ rims and rotors when I bought. Cheapest buy. There was a way to get extra $$ off but you need to call to ask about the discount code.
Carrazzeria. Quicker than diarrhea!
* Last updated by: Rook on 10/11/2014 @ 9:11 PM *
