I posted the link to the demonstration videos of the Guhl reflash for the C14 elsewhere. It would have exactly the same effects on a ZX14.
They got a small HP increase, but the main improvement is the secondaries open extremely early and stay open wide, so its as good as pulling flies without having to physically remove them.
None of the ECU tuners will give you a big horsepower increase, they all leave their ECU A/F and Ignition maps VERY safe (i.e., rich)
Dynotronics also does this, but I have seen no factual information about their version.
With Guhl we got videos of instrumented runs at idle, roll ons from 5th and 6th, and the instrument shows the secondary butterfly position (0 = closed, 100 = wide open), rpm, gear, throttle position, and A/F.
Before I'd give ECunleashed a penny, I'd want to see similar concrete evidence they know what they are doing. Saying you do is one thing, doing it is another.
The way to do this is use the re-flash image on your ECU as a way to remove restrictions (rpm limit, speed, etc.) and simulate removal of flies, and maybe get a couple more HP. Then use the piggy in the exact same way you would anyway, but on a less restricted ECU.
BTW, on the C14, the KTRC still works with the Guhl ECU installed.
* Last updated by: privateer on 10/25/2011 @ 10:45 AM *
