Yes we could feel something, but that was flies opening sooner, nothing else.
I had my flies out. I could toggle the N and 6 or both on together. Yes, there was a change and that meant the flies were out of the loop. That too meant a chemical change in sound. I lost all my vids so if there are any left on ytube, maybe that sub sound can explain that difference in ign/fuel changes. Because when I hacked the N or 6, big noise diff you cannot hear with the human ear. The audio picked it up. There is a big time map(s) change. Has to be. Sounds wild too.
They were slightly more aggressive... I could never get it quite right, only now I know why ugh !
Right. There is that fly map and the percentages of opening. That was a simple factory fix was speed the flies up with that map. So without entering the ECU, outside was not even close to moving the flies to open more aggressively was more like, remove them, hack them.
In the present time We now know Kawi uses the secondary throttle plates ONLY to restrict air in gear grouping.
kit-ECU had the ability to change sprockets and that meant to change the formula in gear sets. I think it's more a sprocket to rpm vs. gear grouping. Same as kawi changing sprockets between gens and back again to a map to gear ratios. So, you do not see that map, but in the kit-ECU software you do. There has to be a formula behind it. If I think curve and passing gears in the automatic trans, that's the A/C shutting off and the ign curve moving to retard. That says no knock under load when passing, right? Trans is tied into the engine loads = GPS? That's if I apply auto trans to engine, I have the trans sensor, yes? I saw the sprocket formula to match too, yes?
This should now give you a clear understanding of what the TRE really does.
Explain that chemical reaction I hack the N or 6. Fuel/ign/rpm are tied together. I hack, I moved 3 variables to different maps. My understanding is the 555 timer is always monitoring me at idle to 186mph and if a sensor fails, I am safe at any speed is that backup. That's my understanding of a sensor... You call it a tre, I call it, Pick a sensor.
With today's tech False claims of timing changes go out the window. Yep once again, there is no such thing as Santa Clause booooo.
Coal in your socks says, I am a 'various' sensor and I do not need this to function. But since it is timed/balanced in the electronics vs. 60mhz, we are handcuffed to the split of the frequency phenom. We change when we run in backup. You cannot separate an advancer with springs, or the fuel signal of that vacuum pull under the main throttle plate. Both are tied together with the rpm, right? I add a wire, I am no longer mechanical, but digital in running. So of course both are tied in electrically is the rpm speed.
Remember? I fail, I revert back to natures 60mhz split. I am n-A and D-J once a low to mid or a mid to high fails, the backup takes over. The injector call being 760mmHg or default to said 'backup.' Once santa puts that in your sock, all answers are explained is do not mess with The Penultimate (60mhz/14.7/1 atm/1 atmosphere). The shop manual between the lines is where I read that. Like I said, you have to know a tiny bits of something before that book makes sense. I walk in with my Pen, and ultimately it makes perfect sense designing a processor that is stuck with formula in bi and one number is nature's call.
The 14R is different.
Nope. The computer bike is generic. Same as a carb bike we talk mikuni or kehin. Same handcuffed principals.
My guess is, this map allows bike to run cooler when idling. In long periods of heavy traffic I go for Neutral. My brain tells me this helps but I have not spent the time to prove this in exact time and temp #'s but it's a safe bet. Testing to prove exactly is needed Hub ?
That would be simple to do. I can run a timing light on the crank, rev in N and rev thru 1-6. Timing changes and now hack it to see the timing change again. I'll try that down the road. Right now, I hacked the PAIR light to shut off, so it's test time.
Hope this info clears up any misunderstanding that some may have due to claims made in the past.
Before those processing books, I was lost in the theory. Now? My bud that gave me those books said good luck figuring out the ECU.
1. I bought that camera to watch the sub shaft.
2. I poked a hole in a cover to watch the ign timing.
3. I had Ivan stimulate the search.
4. I figured out the meaning of analog and digital and how I apply it.
5. I stumbled onto a lockdown that keeps explaining the system.
6. I understand what The Penultimate [lockdown] means in my language, my abstract, gleaned from the code pages in the book.
7. I have this memory of a theme song, and it goes something like, it's how dee tune knee time, it's how tea toot tee time, da-da-da-da-du-waaaa, It's sink or swim me time, it get a fucking line, it's time to wring your neck, here he comes to save the day! It's mighty mouse and a click away. Oh crap this a crappy map I just made!
Oh, here is the bad cell number. I don't have to cry on line for a map...
Romes, are we on the same page? No penultimate, no make sense. Bring the penultimate and it all makes sense. WOT is the penultimate number each time the valve closes? 1 atm. What is the number a turbo pushes to make boost? 14.7 and count boost from there. If this penultimate makes sense, then the other penultimate applies to the ECU. When I read how you explain it, I bring the 1ATMO up against yours/anyone's theory. Convince me or I convince you, someone is right or closer to being right in theory.
I base my theory off the Pen. There is no one to ask short of me trying to get into the propulsion lab down the road some, or head to a high school and hit up some geeks. I'll have to disagree on a few points there, Romes, or my theory is all whack and the shop manual is a lie.
