Thread: New goddies for my ZX14
Created on: 02/24/14 11:35 AM
caps
caps's Gravatar
RE: New goddies for my ZX14
03/03/14 12:02 PM
Can you put other heel guards (made for a zx14) on there? I have a custom set I'm not willing to give up for rearsets.
2006 Ninja ZX-14
2010 Ninja 250
2012 Ducati Monster 696
Blkcasper
Blkcasper's Gravatar
03/04/14 12:03 AM
Caps brake side should work if heal gaurds attach to brake plunger. Shifter side maybe. Uses smaller bolts to attach heal gaurd. Colors may not match
Luvin My ZX14R'S.
03/04/14 2:58 PM
Wow, man buddy she pops
Blkcasper
03/05/14 11:41 PM
Thanks Romans. I been slowly working on her. Got a few mo goodies in the bag to be installed some time soon.
Luvin My ZX14R'S.
03/06/14 9:42 AM
few mo goodies
hmmmmmm,,,,,Do tell ? A little NOS maybe. Smoooookin fast. Don't click
03/06/14 11:49 AM
major spanking
Cornelius
Cornelius's Gravatar
University of Okoboji
03/15/14 2:47 PM
Mine did not come with the brake light switch :(
2013 Super Fast SE ZX14R
Cornelius
03/15/14 5:55 PM
Blkcasper- do you want to sell your brake light switch that came with your rearsets?
Blkcasper
03/16/14 2:25 PM
I decided to install it. But its not working for some reason. You would be better off with installation an inline pressure switch. One that replaces the banjo bolt on the brake plunger assembly. There about 15-25 bucks
* Last updated by: Blkcasper on 3/16/2014 @ 2:32 PM *
Luvin My ZX14R'S.
Cornelius
03/16/14 3:10 PM
Ok. Cool. Thanks. I'll hold off on that one until I'm ready to install steel braid brake lines.
Blkcasper
04/02/14 11:38 PM
Just got my new shift rods in today. Anitori quick shifter going in this weekend. Ill post up pics of install. It'll take longer to remove plastics than it will to install quick shifter.
* Last updated by: Blkcasper on 4/2/2014 @ 11:40 PM *
Luvin My ZX14R'S.
damnZX14
damnZX14's Gravatar
04/09/14 7:55 PM
As far as foot peg height and lever size, how do these compare to the factory rearsets?
I am a tall rider (6'6") and I am considering the Buell foot peg swsp for more legroom. Do these go as low as the factory foot pegs?
Also, I sometimes feel like I'm riding a little pigeon toed.
2006 passion red ZX14 30k miles
BMC race intake, secondary flies removed, pair block off, Brock's street-meg, PC-III (brocks performance map)
Blkcasper
04/09/14 10:29 PM
Damzx14 these have way more adjustment options. You can go forward, higher up, lower, backwards, and also set them at an angle. Roughly about 2-3 inches in any direction from stock position. Shift levis a little shorter than stockr can also be set at any angle that's comfortable for you. Pegs are aluminum and much griper than stock rubber ones. I haven't hqd any issue's with feeling any vibrations. I've put almost 1k miles since install. Also allows me to switch to reverse shift pattern.
I wear a size 13.5 shoe so foot peg to shift lever is an issue.
Here's another option for you. I had this setup before going to the fully adjustable rearsets.
Foot pegs rotate 360 degrees to allow you to put Pegs higer or lower or backwards. Replaces stock pegs, no modification needed. Cycle pirates brake and clutcb levers can be adjust by lenth. shift peg Is a little shorter than stock, a spacer and longer bolt can fix that. I had no issues with them.
Luvin My ZX14R'S.
bmacknyc14R
bmacknyc14R's Gravatar
04/10/14 5:34 PM
Very nice looking bike casper
HB3BUTLER
HB3BUTLER's Gravatar
04/11/14 1:31 PM
I just put mine on and cut about 40mm off the shift rod and re-tapped it for normal shift. I also made some 12mm thick spacers that allowed for a 20mm drop so I can ride without cramps (long legs). Lovin the Chinese specials! Will post pics later. And +1 for Locktite!!!!! Went on a 40 mile ride and the shift peg almost came off.
Some junk & stuff on my bike and a hole in my head for riding it!
HB3BUTLER
04/11/14 5:52 PM
http://www.zx14ninjaforum.com/userfiles/hb3butler/20140411_194600.jpg[/img]
Blkcasper
04/11/14 6:09 PM
Looks awsome man. For half the price of what I would pay for vortex, sato, ect. They do what I need them to do and I can't complain. Got over 500 miles of hard riding on them so far and no issues.
Luvin My ZX14R'S.
poison
04/20/14 9:24 AM
I was looking at these but the description only says you can move pegs up or back, whereas I want to lower my pegs.
Does moving them back have same effect as lowering pegs?
Thanks
Nigel
poison
04/20/14 9:36 AM
I have stock exhaust on bike still as well
Blkcasper
04/24/14 12:10 AM
If you're just looking to lower the pegs the 360 adjustable peggs are are probably the cheapest way to go. The fully adjustable ones will work, getting shift rod set correctly for what you want to do may take some extra work. With Just lowering the pegs, you will also need to change shifter angle .
Luvin My ZX14R'S.
Blkcasper
04/24/14 12:15 AM
Anitori quick shifter installed. Michelin pilot rd4's on the way...
Luvin My ZX14R'S.
Louisloong
11/19/18 1:47 AM
Hi, How do you install the brake lights to the rear set?
Thanks.
Blkcasper
11/19/18 11:04 AM
You have to purchase an hydrolic brake switch that plugs into the brake master cylinder
Luvin My ZX14R'S.
