Can you put other heel guards (made for a zx14) on there? I have a custom set I'm not willing to give up for rearsets.
2010 Ninja 250
2012 Ducati Monster 696
Created on: 02/24/14 11:35 AM
caps
Blkcasper
Blkcasper
Cornelius
Cornelius
Blkcasper
RE: New goddies for my ZX14
03/16/14 2:25 PM
I decided to install it. But its not working for some reason. You would be better off with installation an inline pressure switch. One that replaces the banjo bolt on the brake plunger assembly. There about 15-25 bucks
* Last updated by: Blkcasper on 3/16/2014 @ 2:32 PM *
Cornelius
Blkcasper
04/02/14 11:38 PM
Just got my new shift rods in today. Anitori quick shifter going in this weekend. Ill post up pics of install. It'll take longer to remove plastics than it will to install quick shifter.
* Last updated by: Blkcasper on 4/2/2014 @ 11:40 PM *
damnZX14
04/09/14 7:55 PM
As far as foot peg height and lever size, how do these compare to the factory rearsets?
I am a tall rider (6'6") and I am considering the Buell foot peg swsp for more legroom. Do these go as low as the factory foot pegs?
Also, I sometimes feel like I'm riding a little pigeon toed.
Blkcasper
04/09/14 10:29 PM
Damzx14 these have way more adjustment options. You can go forward, higher up, lower, backwards, and also set them at an angle. Roughly about 2-3 inches in any direction from stock position. Shift levis a little shorter than stockr can also be set at any angle that's comfortable for you. Pegs are aluminum and much griper than stock rubber ones. I haven't hqd any issue's with feeling any vibrations. I've put almost 1k miles since install. Also allows me to switch to reverse shift pattern.
I wear a size 13.5 shoe so foot peg to shift lever is an issue.
Here's another option for you. I had this setup before going to the fully adjustable rearsets.
Foot pegs rotate 360 degrees to allow you to put Pegs higer or lower or backwards. Replaces stock pegs, no modification needed. Cycle pirates brake and clutcb levers can be adjust by lenth. shift peg Is a little shorter than stock, a spacer and longer bolt can fix that. I had no issues with them.
bmacknyc14R
HB3BUTLER
04/11/14 1:31 PM
I just put mine on and cut about 40mm off the shift rod and re-tapped it for normal shift. I also made some 12mm thick spacers that allowed for a 20mm drop so I can ride without cramps (long legs). Lovin the Chinese specials! Will post pics later. And +1 for Locktite!!!!! Went on a 40 mile ride and the shift peg almost came off.
HB3BUTLER
Blkcasper
poison
poison
Blkcasper
04/24/14 12:10 AM
If you're just looking to lower the pegs the 360 adjustable peggs are are probably the cheapest way to go. The fully adjustable ones will work, getting shift rod set correctly for what you want to do may take some extra work. With Just lowering the pegs, you will also need to change shifter angle .
Blkcasper
Louisloong
Blkcasper
