How about opening up yer oil filter...lookin at those pleats?
That's what I plan to do. I saved the filter. I also strained all of the oil through a paper towel. Nothing. Nothing in the bottom of the drain pan either.
That chunk I don't think could get up inside the motor...do you?It HAS to go through that filter if it's anywhere at the bottom of the motor,doesn't it?
I believe you are correct on both. It could damage if it originated in the motor but I would say very unlikely to cause harm if it originated down below.
Those magnet plugs really DO help IMO
I guess they do. Most importantly, You will know if there is any steel waring in your motor. I'm sure it is normal to have a tiny bit of super fine dust so little maybe you can hardly see it. Big pieces could mean something is getting ready to let go---which is why I bring this up.
I see looking at the big one...it's got a curved surface on one side...looks like it to me anyway in that pic.
Yes, the surface facing us is curved. Almost like the once sharp, square edge of a gear tooth.
.You say you clunked a shift or something...slammed it...whatever i was you said.You don't think MAYBE it chipped a piece off the gear tooth in there somewhere?
Yep. If you never had it happen, I gdon't recommend you try but if you miss a shift and end up between gears you are in a false neutral. You wind on the throttle and WIIIIIINNNGGG!! you know. If I knew how all that junk in there worked I'm sure I would know the best thing to do if that happens. It is extremely rare using the clutch, the gears just flow one to the next with a little toe nudge. The quickshifter requires a more definite input on the shift lever. The best thing to do is pull the clutch and roll to the road side at idle so everything is motionless in there and click it in. If you do that on the fly, it will bang in and I swear I heard a grind too, constant mesh or not.
It's hard to say what the noise was. NOt a long drawn out vibration like gear teeth slipping. I think it was more of a very short CRACK like two teeth stuck against each other and they slipped and snapped together when I forced the shift. Ugly noise.
even IF it did somehow chip something from a tooth that small...it most likely won't hurt anything.I wouldn't worry about it.It got caught at the plug...i
I believe you're right. Just a little instant ware on a tooth in there. Hate to have it happen but this bitch has 30K miles on her and I got her to ride fast. If she breaks, I will fix until one day ..NEW BIKE!!
* Last updated by: Rook on 5/10/2012 @ 10:01 AM *
