Created on: 03/25/23 07:04 PM
lytnin
RE: amazing
03/27/23 5:56 PM
I want you to look at the split second before impact.See the star shaped flash,like looking at a streetlight and you see the star shaped flash.
Now look at the video again at a slow motion.That star shaped flash is actually the rock electrically overloading itself right before the hit.That's an ARC flash.Not some simple rock hitting a surface.That means the 'explosion'happened before the hit.What you see is an electrical connect from - to +(or vice versa depending).And the resulting blast flow is going low and across instead of high above the impact.The 'lighting up the surface' isn't happening because of the closeness of the flash to the ground and the amount of low lying debris covering some of the view of what happened.If the polarity was a lot greater..you would see an electrical streamer connecting up from the surface to meet it...however long that was considering the charge.Just like a rainstorm and lightning.Earth to cloud connections(not always).
The universe is electrically controlled.EVERY body out there has an electrical potential in it.Gravity isn't holding things where they are.Gravity is the weakest force in the universe.
* Last updated by: Grn14 on 3/27/2023 @ 6:09 PM *
RE: amazing
03/27/23 6:20 PM
Ancient peoples around the world saw these electrical phenomena.Google 'Petroglyphs' and native rock art.Those people saw those things...10-14,000 years ago....Climate change?You can bet there was LOTS of climate change when these people saw this going on.Terrifying.Our solar system was aligned polar to polar with our other planets...The lower one is millions of light years away...but there was a time when there was a massively HUGE electrical polarity deal happening.The planets aren't now where they were then.At polar axis.Mainly what you see in these petros and rock art are 'above earth' happenings.This wasn't a one off happening.THis took years to occur and resolve as they are now.
People were definitely in awe and fear of what was going on.
* Last updated by: Grn14 on 3/27/2023 @ 6:27 PM *
chrly
RE: amazing
07/04/23 8:14 PM
Containment. This causes a leak in the garage say, it can blow up the whole house. Open a can of gasoline, it will just vaporize and turn the gas stale. Can't smell hydro.
That's water mixing with metal. I'd say the rings won't last during hot/cold cycling. More crater the material. More like it needs ceramic as the engine parts, silicone [melted glass] too is the guess.
