Can anyone turn off the FI flashing? Then, is it in method or are we using sensor? I can't ask the programmers/EE's. I have to follow watt you say and that book abstract. If things come in 3wV as that code page; if the 3A's don't have you in the side of the road... Are we seeing a 3 ring circus we do not follow some sort of gotta make it speak.
No one is speaking it. Unless someone can explain it better than the book, my AFR, the 2 open and closed loop bikes in my possession just so they answer some of my questions, not this parallel points style. That is parallel fire. Same ol' spark box now. Those had advancers.
Say, after all was said and done with the 1980's and that spark box with the electronic advance set = No adjustment. Didn't a fuel jet change do wonders? So, no ignition change, just more gas. How much gas is coming out my ass I say there is the more air mentality and the same air farm group.
I pointed out the basics so you walk it, not step in it. I said, "Show me more air in a glass filled with the 3A's = Solid-liquid-gas? If I left the glass on the table, meaning, do not touch the advance, did I not add liquid to the glass? Was that a displacer for fuel [or air]? If I have no fuel, but spark and compression I do, I think that says the ratio has changed to zero fuel.
If I add more liquid to the glass, is that not like a jet change, more went in than air? Did we add MORE? I think we added more gas than air and it fired with more energy. But, was that not the SAME no matter how you look at how that glass was filled? Even in the static, that glass is filled full of air. Will the engine start?
If you can't get on the same page with SAME... Shit on the MORE AIR Mentalities! You went zero tuning. You are not there yet. Bring the shit loads of loads if you understand a clue here. You need to know the basic bottom line shit before you open that page to that surface abstract that dose not talk about glass filling basics MORE OR LEANless>
* Last updated by: Hub on 10/21/2011 @ 11:40 AM *
