Agree with above. Nels at 2Wheel DynoWorks has a reputation for standing behind his work.
He even offered to fix all the flashes that CBlast fucked up
Created on: 06/27/15 01:24 PM
lytnin
RE: Flash Negatives!
12/10/20 7:53 PM
Yeah right. When I called and asked they offered to take $10 off the price of a tune. I honestly do not blame them but after one reads about how they are working with everyone and they basically say it is your problem and literally hang up on you then they are not nearly as great as some here think. $390 plus shipping was their quote plus shipping then the hang up. I will keep riding the FJR as nobody has screwed me over on stuff for it. I agree that Nel's was not the one that screwed me as I and others got the Cblast weenie put to them.
12/11/20 2:58 AM
My question is: has anyone done a flash or other similar add-on and experienced no problems at all? Does everything work as it should with all the benefits promised? Thanks.
I have a Gen1 ZX-14 with a Power Commander and I've used with four maps. I never had a problem with any and the PC5 has never caused a problem either. The main improvement was the flies opening throttle response. Any improvement in power is almost imperceptible. One thing I like is that my 14 will now pull smoothly from 2000 rpm at WOT in 6th gear now but that was due to my own refinements with Auto Tune. Optimizing the timing may show a more noticeable improvement but I haven't messed with that yet. There was a guy on here years back who did videos of top speed runs before and after a flash. Timing the videos with a stopwatch is a little crude but it's probably a better comparison than going by the seat of the pants. I believe he was slightly faster without the flash. It was within a few tenths of a second I believe. To me, that's no difference. I think Vic had his stock exhaust, didn't he?
I have a Bazzaz on my Gen2 busa and have only used one map. It runs good too.
* Last updated by: Rook on 12/11/2020 @ 3:02 AM *
12/11/20 5:01 PM
I should add that the flies open response was NOT improved by the base maps I used. It was smoothed out by my Auto Tune adjustments. I think Romans' map was pretty good as is for the flies open fueling but I would have to look back at notes I took to say for sure.
It seems to me having a custom tune from a reputable tuner will probably yield the best results. Either that or do it yourself if you dare. An LSR course would be an ideal place to use Auto Tune. It's really risky doing it on the road. It was too risky to be called "fun" in my book. Also, I don't recommend chopping the throttle at 180 mph like I did. I got a serious front end bounce one time. You can install a switch and just shut Auto Tune off instead of cutting the throttle. Auto Tune doesn't work if you roll off the throttle. It destroys all the adjustments you would have between the time you hit top speed and when you get it rolled to 0% throttle and those are the most risky ones to acquire. Switch off, then it doesn't matter what you do with the throttle, the adjustments are preserved.
* Last updated by: Rook on 12/11/2020 @ 5:02 PM *
Kabcar
12/15/20 8:52 AM
Update: Since getting the Ecu back (Corrected),A few test runs here and there due to weather. The bike is running as it should...GREAT! No jerking or stuttering anymore,Smooth power delivery at low rpms, Lethal up top. My advice when dealing with Performance Tuners... Keep all documentation of your experience with them, that way if they decide to become dismissive of fault, you can blow they spot up! Good riding and Bundle up!
* Last updated by: Kabcar on 12/15/2020 @ 8:54 AM *
extrapolator
busabim
01/06/21 1:45 PM
I have Ivan's flash on 14R for almost 2 years; First with dual slip ons and now with the Brocks full system.
My bike is a 2014 with no catalytic originally. No issues, wicked mid range and now with the Brock's hold the F on at high rpm.
I have used Ivan's products since the days of the TRE and they work as advertised and he stands behind his work
With the Brock/Ivan combination, I can get 400 KM ( 250 miles) to a tank averaging more than 75 mph
BB
* Last updated by: busabim on 1/6/2021 @ 1:52 PM *
motero
03/05/21 11:21 AM
nord,
Let me point you to this url...
https://mototuning.ie/product/kawasaki-zx14-ecu-tuning/
"MotoTuning
about 2 weeks ago
So @woolich_racing have tried there hand at tuning BMW motorcycles & it hasn't started to good for them, bricking ecus leaving customers without there bikes. WE DO NOT USE @woolich_racing products to tune your motorcycle. All of our tunes are developed in house using high end professional software and hardware. We also have BMW genuine..."
Just ride the bike and know you won't have a flash story to tell.
Signed,
NOLTT (no one listens to turtle)
gary at mototuning flashed my zx, flawless
jstewart
03/16/21 10:11 AM
I like busabim have used Ivan's products for a long time starting with his jet kits. When Rob Muzzy started selling his jet kits rather than developing his own it said a lot. I also used his TRE on my first gen ZX14 which worked as advertised. I used a PC on my first ZX14R in 2012 because that is what Brock used on my project bike Louisville Slugger. We later used a Guhl flash with the PC. Guhl worked with me to develop a flash for my Honda VFR1200 which worked out very well. On my 2nd 2012 ZX14R with a Akra 4/1 pipe I am using a Ivan flash which has worked flawlessly. I took the bike directly to Ivan in SC and got a good look at how he develops his flashes. In all cases he buys the bike he is developing a flash for and uses both a Dynojet 250 and road testing to refine his flashes. I don't know if his flashes produce as much HP & TQ as the Guhl/Brock flash but I like the refinement he gets from buying and road testing the bikes he develops flashes for. Like a lot of talented creative people he can sound a little abrupt on the phone but he backs up his products. If you are drag racing I would go with Brock/Guhl but for the street I would use Ivan. I have had both and they are both good and stand behind their work. Just my 2c worth on this subject.
11/05/22 11:40 AM
I realize this is a couple years old but just to clarify if Rook was referring to the testing I did, and not someone else "who did videos of top speed runs before and after a flash". If that is the case that he is referring to someone else and some other test (as there have been some) but he mentions ME so I assume he is referring to the testing I did.
- My testing was not done using a stop watch. The testing was based on 30 fps video recording, using the timestamps of each frame of video through video editing software. This means the accuracy of the times was extremely accurate, and with less than 1/15ths of 1 second beginning to end (because there was a start, and a stop, meaning 2/30s which is equal to 1/15). That is .06 seconds maximum discrepancy, which is less than the time of the "blink of an eye" (.1 second).
I posted the video recordings on youtube (it's still up there), and I recall some dipstick used a stop watch to try to analyze the times, which was completely unnecessary and introduced gobs of potential discrepancies since they were literally trying to time by watching the video and clicking a stop watch. I don't remember who that was, but that's what Rook remembers NOT what I actually did with the testing.
- it wasn't "top speed" it was roll on test in both 3rd and 4th gear (3 runs each) from 4k rpm to 10.5k rpm
- bike has/had a Yosh 4:2:1 SS/CF exhaust, I kept the OE ECU stock and bought a 2nd ECU to flash, so I could swap them in and out
- as far as the outcome Rooks recounting is accurate, which was something like within .1 second on average
11/13/22 12:48 AM
Yep it was you I was talking about. Hi Vic. Stopwatch, video, whatever, if the difference is that small, the average everyday rider isn't going to gain anything for everyday riding. Maybe a highly competitive racer. I did my own AFR tuning and I swear the difference was ---not noticeable. That was just AFR, I didn't tune anything else. There are benefits to AFR tuning but it wasn't speed from my experience. Go ahead and do it but don't expect to feel a huge change in the power of the bike. Maybe none.
