Thank you very much Eric...yes that all makes sense. I could see fastenning the wheel holder I have to a wooden pallet with some U-bolts. Then place the palet on cynder blocks to raise it higher.
I see the center bar is a lot longer in your pic. It would require a lot more than just dropping a steel pipe over the threaded rod on mine. That thing would not take much prying before it bent around and got loose. Would require some major bracing which prolly would mean some welding.
That NoMar bar is $125. I believe it was mentioned earlier in this thread or perhaps another thread. Now that I know I can do this and will continue, that bar would be a worthwhile investment. Right now, my rim holder and tire irons and rim protectors cost about as much as that NoMar bar.
BTW, thanks for condolences on the rim scrape. It is really minor though. It's right on the edge and about the size of a grain of rice. I couldn't ask for a more gentle wop upside the head. Lesson of that day: WHen using rim protectors, ALWAYS tie them off so they CANNOT slip out of place. THen you got bare iron wedged between your tire and your rim. I slid a plastic cottage cheese lid in there to help protect the rim while I pulled the iron out. That CC lid was sliced right through. second lesson of the day: DON'T use plastic bottles in place of rim protectors....no matter who tells you they work as well or better. If they split, they don't work at all.
