Yes/no. Only way to tell is to pull it off, ride it:
TRExtratio'd Rich = Was the map made with the tre? If so, then yes, remap. Was the tre an afterthought and the map was not made with the tre setting? Then, no. There is no need to change map if the dyno charts do not state what is being pulled with what mod. See how you are still up in the air with that Q to be answered?
Map Rich = Say the map now never had a tre mod added. You are now PC rich. Are you hurting bike that way? No. Did you hurt the bike with the tre being in a rich/safe, won't blow up the bike at any speed? Nope.
Bone Stock = If you took the PC off, how can this hurt the bike? It runs rich as is. I can't wink-wink no need a PC, but no one listens to turtle. Gotta bring those aftermarket open pipes without a pc, all being an open track bike and that is an instructor with a zx-10? You see now a zx10 or a 14 having a tuning problem with a street pipe all quiet on the west torn front like nothing is popping out of the bike like a rod, the piston seized up like the rod turkish taffy'd out the case?
Case? I rest my case IS.
_______________________________________________________________________________
Yes, the tre is a twitchy ride. It gets complicated. Basically stated, if I were to install my ignition's base setting, I want to know where it sits with the timing light? I then tighten down the spark unit. That is a digital/one signal switch in a way. Think of it like a light switch. That is single mode or fast mode. After we set that timing, we plug in the analog.
In other words, we changed the on/off light switch feel, for a smoother analog or the wall switch was changed to a rheostat type switch. Twist the throttle and you can see how smooth and controllable the power is now. But if in on/off light switch mode like the tre, it is twitchy, snappy, on/off is that throttle application. So yes, there is a big performance difference with that safe mode.
That difference is sort of a redundant setting if say the sensor failed. That is why, technically, the sensor failed in one of 3 ways, so yes, you get your shift window back. The sensor has not failed, just shorted somehow, without blowing a fuse that is.
So, yes, you are wasting gas because of the safe mode it puts itself in. Yes, you are wasting gas because the PC is not needed on a street bike with zero mods. A mufflered pipe is still a quiet, show me how open is open to you needing a pc like you said. Do you really need more than you can handle?
I say, yeah, I can handle it. The thing you have to ask yourself is, do I need to waste all that gas when I can get to 186 in maybe more seconds than your mod can in less time? And it sure is not a half a minute difference. Nor, a 15 second difference on the street? Get real!
Pull all the crap off till you get used to the bike. Bike still goes 186.
Isn't she a sweet ride you just have to, have to get to 186 in so many seconds? Is that you, guy?
She can do it. Twist away we need pig parts?
* Last updated by: Hub on 10/23/2011 @ 9:55 AM *
